Question about Computar H6Z0812M 1/2-inch 8-48mm f1.2 6X Motorized Zoom, 3 Motors C-mount
Do I need a driver
Camera will not work. The connection says it's connected. do I need a driver to get my computer to run the camera
Driver download
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
May 05, 2013 | Vivitar ViviCam 5386 Digital Camera
My nikon S4100 will not connect to my sony vaio laptop
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
May 21, 2012 | Nikon Coolpix S4100 Plum Digital Camera...
I have a Vivitar Vivicam 8025 camera, 6 months old. After moving I can't find the driver to install on another computer. I can't get the driver from the Vivitar website. I need to find another source for...
You should be able to request the driver from
http://vivitar.com/products#Digital Cameras/24/13/Software Download
You also might want to consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 10, 2010 | Vivitar ViviCam 8025 Digital Camera
My finepix f460 has no driver ill need free driver
http://www.fujifilm.com/support/digital_cameras/software/usb/index.html
You might want to consider NOT connecting the camera to the computer.
Jul 08, 2010 | Fuji FinePix F460 Digital Camera
Driver does not work
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 18, 2009 | Pentax Optio S4i Digital Camera
Downloading my pictures from the canon powershot s200 digital camera to my computer
Sep 07, 2008 | Canon PowerShot A75 Digital Camera
Digital camera keychain by bell marscam
After you delete very thing you have installed on your computer that has anything to do with your camera,
Download this and don't have your camera plug into your computer then install this it works....
: MR97310c Mini Digital Camera Drivers Version 2.03 All Functions work.zip
* Turn on your computer or reboot.(this ensures consistent starting point)
* Connect your camera to the PC using USB 1.1 cable.
* When the found new hardware window opens install drivers automatically.
* * the found new hardware window may open up more than once. If so then click install drivers automatically for each time it opens up.
* Double click the "PCCam" shortcut in your "All Programs" menu and follow directions.
If this does does not work ...
* Check to make sure the USB port is working properly in device manager.
* Make sure your computer is running a fully updated version of supported Microsoft Windows platform. Check computer properties for version of OS.
* Try having the camera turned on before connecting it to your computer.
Jun 16, 2008 | Jenoptik JD C160 Digital Camera
Keychain camera
It would help to know by what means you are attempting to connect; airless or cable?
If cable, you can try this:
Shut your computer down, have the camera connected and turned on, then restart your computer.
If you are running Windows (it helps to know this little detail too), it may see the camera and install its own driver for the device.
If Bluetooth or other non-cable protocol, it would still make sense to have the camera on and reboot your computer to try to force recognition of the 'new' device.
May 29, 2008 | Digital Blue American Idol Keychain...
Connection between camera and computer
What operating system are you using? Is you camera connected via USB? Have you tried using another USB port? Did you make sure to install the software before plugging in your camera?
Generally if you are running Windows 98, you will need to reboot after installing the software to even have a chance of the camera being recognized correctly.
If you are running Windows 2000, XP or Vista, the camera should be recognized and a driver installed or searched for from the CD software you installed before plugging in the camera.
Sometimes if you plug in the camera first without installing the software, the PC finds a new device with no driver. You can see this by going to Control Panel -> System -> Hardware -> Device Manager and you should see and exclamation on a device in the list. You need to remove this item and reboot your PC.
Now install the software first and when the install is done, then plug in your camera. Generally this works out pretty well.
Apr 29, 2008 | Canon PowerShot A80 Digital Camera
I have windows vista im looking for drivers so my cobra 6415 will work
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use a photo cataloging program.
Nov 16, 2007 | Cobra Digital DC6415 Digital Camera
Computar H6Z0812M 1/2-inch 8-48mm f1.2 6X Motorized Zoom, 3 Motors C-mount Logo
52 people viewed this question
Top Computar Cameras Experts
Steve
Are you a Computar Camera Expert? Answer questions, earn points and help others
