Question about Kodak ESP 5 Printer
Our printer has no paper in the machine but we can not get rid of the "X error" paper jam ???
4 Suggested Answers
SOURCE: ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
Posted on Apr 12, 2009
pineworks
  • 4041 Answers
SOURCE: printer error paper jam and no paper to be found!
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 30, 2010
SOURCE: My kodak All-in-one printer ESP9 goes instantly in
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
Posted on Jan 14, 2011
Cannot get rid of error message: Paper Jam, Front, Rear
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=eu&c=gb&lang=en&prod=mfc235c_eu_as
Mar 04, 2014 | Brother Multi-Function Center MFC-240C...
PHASER 3100MFP SAYS PAPER JAM BUT NO PAPER IN MACHINE
Hi there, if you have experienced a paper jam prior to this error, then try to inspect the rollers as there might be tiny pieces of paper shreds that might be stuck there. Or blow a canner air or a blower inside the printer to get rid of any obstructions.
Hope this helps. Thank you for using FixYa.
Dec 16, 2010 | Xerox Office Equipment & Supplies
Error code comes up on my new never Epsom printer reads paper jam
If this is brand new, it needs to have its ink cartridges installed and paper in its tray. It won't be happy until it's completely ready to go.
May 16, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Ive got a pixma mx700 printer and im getting the 5c00 error how do i get rid of this
Error code 5C00 refers to possible paper jam or product needs reset or service.
It is possible that a previous paper jam has left a piece of paper inside the machine. If you cannot see any paper jammed at either input area, open the rear cover and look in there. Otherwise, you can try to reset the product:
Reset the printer:
1. Turn the printer off with the Power button
2. Disconnect the data cable from the printer
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Attach data cable.
4. Turn the printer back on
If all of these suggestions fail, your MX700 may require repair service.
Dec 28, 2009 | Canon PIXMA MX700 All-In-One InkJet...
How to clear internal paper jam on CLX-3160FN Samsung Multifunction Printer
Get rid of it. Your problems will only get worse. Mine is going to the landfill.
May 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Paper jam error
there are sensors located in the paper cart area. try to check if there foreign objects obstructing your sensors.
Apr 18, 2008 | Canon I900D InkJet Photo Printer
Kodak ESP 5 Printer Logo
16 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
