Question about Brother MFC-210 All-In-1 Print/ Scan/Copy/Fax and Photo Center - Twenty Dollar Mail-In Rebate Printer
I have replace all of my ink jet cartridges and it sees the black and magenta, but I am still getting the ink empty error message for cyan and yellow. I have removed and reinstalled atleast 20 times, unplugged the unit etc. etc. and I am still receiving the error message. Is there anything else I can do myself?
  • 27 Answers
Ensure that you buy ink catridges from reputable store and there is need to original in from your printer manufacturers.You may also uninstall the printer and reistall with driver CD
Posted on Jun 18, 2009
  • 97 Answers
Did you make sure to remove the stickers covering the print heads? double check. other than that you can clean the heads with a qtip and isopropyl alcohol, they may be dirty with old ink and not able to see the new cartridge properly.
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
The light for the magenta cartridge on my iP3500 printer goes off
The cartridge, as well as all ink jet cartridges has a chip inside that tells it how much ink is in the cartridge. Your cartridge is LYING, except it prevents you from printing without all cartridges working. ( same for my 6 color epson ). You need to replace the cartridge. I get my cartridges at a yahoo store called Inks4less. They have good quality for cheap.
There was a study done, analizing the amount of inks left in inkjet cartridges when they indicated empty, and the range was 7% to 25% ink still left.
Oct 03, 2009 | Canon PIXMA iP3500 Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Error message is telling us we are out of ink we just replaced
This problem needs to be addressed by an Epson service center. It needs disassembled and probably needs parts replaced that the leaking ink damaged. Sorry.
Dec 28, 2008 | Epson Stylus Photo RX500 Printer
Misreads ink tanks: says full ones are empty and there are 2 cyans, etc.
I had the same problem -- error message saying two cyan print tanks installed. Nothing helped (including disconnecting power cord). Then found I had an older cyan print tank still in its pack on hand, Installed that. No further problems. Assume this means print tank giving error is part of a faulty batch so am returning to retailer for refund from Canon.
Oct 24, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
96 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
