Question about Genie Company Televison & Video
Is overhead door remote model TBSTO TYPE1 compatible genie
5 Suggested Answers
SOURCE: Reprogramming a Genie garage door receiver
I ned a akai audio timer DT-100
Posted on Aug 18, 2009
blanchettohd
  • 143 Answers
SOURCE: Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
Posted on Jun 06, 2010
SOURCE: genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
The only button that could be programmed on my remote was the 3rd or bottom button. The top two appeared to be programmed but would not operate the door.
Posted on Sep 14, 2012
SOURCE: how to set acsctg type 2
I have a genie
model 2060L And a new remote 3 botton and need to get it to open the garage door I don have a clue how to program it?
Posted on Jun 17, 2013
My Genie door opener does not seem to want to connect to the Chamberlain remote control. Please advise!
If you have a universal remote or a max remote you can go to chamberlain.com to check compatibility. if it is not a universal or max remote it won't work with any genie product.
May 04, 2015 | Building Materials
Looking remote chain for Legacy overhead door opener. Model #696CD/B
Legacy openers use the same remotes as Genie Intellicode 390MHZ. Should be able to get one at any lowes or home depot.
Aug 09, 2011 | General Electric GE 13-438 Overhead Garage...
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
Genie model ACSD1G will not program to Linear door opener model # LD033.-- need help doing this.
Most of the time, keypads and remotes are not compatible with other manufacturers. You would be better off getting a universal keypad, which should work. Double check the older opener to make sure it is on the list of compatible devices.
Also, make sure you check the balance of your garage door periodically to make sure your springs are counter-balancing the garage door properly. If not, the lifespan of the garage door opener will be substantially shortened. Click here for a how-to video.
Feb 28, 2011 | Genie Company Genie Gwkp Keypad...
Will not program
FIRST VERIFY THAT THE REMOTE IS COMPATABLE WITH YOUR DOOR OPENER (THEY CHANGED THE FREQUENCY A FEW YEARS BACK.
CHECK GENIE.COM
IF YOU HAVE THE CORRECT UNIT THE WEBSITE WILL GIVE YOU INSTRUCTIONS ON THE CORRECT METHOD TO PROGRAM.
NOTE IF YOU PUSH THE BUTTON ON THE REMOTE THE LITTLE LED ON THE POWERHEAD SHOULD FLICKER. IF NOT, YOU MAY HAVE A DEAD BATTERY OR THE WRONG REMOTE.
Jan 22, 2011 | Genie Company Genie Intellicode GITR-3...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
Have a 3 Genie remote and the center button works in programming one garage door, but the side buttons will not work to program the other garage door. Can you help?
The other opener has to be a genie, compatible genie to be exact. An older one will not work with new devices. If it will not program it will be the openers fault not the remote. Thanks BB
Feb 16, 2010 | Genie Company IntelliCode GICT390-1BL...
Televison & Video Logo
127 people viewed this question
Top Genie Company Televison & Video Experts
Are you a Genie Company Televison and Video Expert? Answer questions, earn points and help others
