AudioBahn A2200HCT Car Audio Amplifier Logo
Posted on Jun 18, 2009
HELP PLEASE My ampstatuslight comes on but not the amp what going on ?
  • Anonymous May 11, 2010
    is the amp grounded properly
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jul 18, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
5802
Points
22
Your amp is die.... Go to the service center of your amp
Sony bravia kdl-60w600b and trying 2 hook up my sony theatre system ht-m7/ht-m5/ 4 some reason it reckenise the amp but the audio system is active but there is no sound coming out of it plz help me?
Hi
please connect your system through HDMI cable & select HDMI port which is ARC written on led then after connecting press sync on batten & select options for your system this is one step if sound comes through your hi fi then ok otherwise go to av setup & select audio out put sound must come
2answers
BF-888s
Any one reading this post help please...
cheers,
Peter
1helpful
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Sub power comes on consistently for about a second and thuds
u might have bridged the amp below is ohm load, if that the case run the speakers in series instead of parraell !
Top AudioBahn Car Audio & Video Experts
Jerry Naidoo
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
