Question about Locks & Locksmithing
Need to reset safetron digital lock
Need to reset digital lock
I am locked out of my safetron Aanon home safe despitechanging batteries. What can I do?
It has defaulted back to the original code I expect. Try the original code.
Feb 13, 2017 | home Home Security
I need a reset code for phone screen locked
There's no hard reset on this phone. Here's what you want to do. If your phone is currently locked on your home screen pres 111111(do not press unlock because it'll only give your 4 spaces, just do it until you see the 1's appear). You should see Options or Service appear,if Options, select options then service, if service select service. You should see reset lock, select it then click yes. It'll ask you for a 6-digit code. This is called the 6-digit service programming code or SPC, just call MetroPCS' customer support and have them give you the SPC, once you've entered it, your phone's lock code will reset to 0000 or the last four digits of your phone number. If it'snot locked it'll be easier for you to enter 111111 on the home screen. Follow the same procedure.
Aug 28, 2013 | Kyocera wild card Cellular Phone
Schlage keyless lock lost 6 digit code and no sticker inside either
You will need to take the keypad look off of your
door and record the 6 digit programming code and the two factory
default PIN codes. You then need to perform the factory reset to
erase any codes and restore the lock back to the factory defaults.
This procedure is outlined, as well as the programming of the device, in the attached instructions.
http://www.factorylocks.com/PDFs/Programming%20Instructions.pdf
Regards,
Leslie
Factorylocks.com
877-345-6257 (877-34-LOCKS)
Jan 13, 2013 | Schlage FE595 Plymouth Electronic Keypad...
I need to reset my phone, but im locked out. How do I reset it if it's locked and I don't know the code?
What is your mobile and model ?
If you forgot the security code you have to reset you mobile. Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means just visit here Simpleunlocking.com for the master reset code service and get the reset code........
May 14, 2012 | Cell Phones
What is the model of your phone? If it is a Basic model of any Nokia phone you can have a try at www.Theunlockarena.com This site provides master reset code for most of the Nokia model phones. All the best mate.
May 14, 2012 | Lands Phones
Cannot remember lock code four digit number and it is not the last four digits of my cell number, need to unlock so I can erase some locked numbers
can u specify your phone model ?? in case if its a nokia phone try reseting it using master reset codes from http://www.superunlockcodes.com/ to reset it back to normal
Jun 09, 2011 | Cell Phones
Need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Apr 06, 2009 | Safe International Digital Electronic Safe...
My Daughter Forgot the 4 digits lock code, for her motorola V6.
Most cell phones after they get programmed, the default lock key would be the last 4 digits of your cell phone #... try that
if that didn'rt work try 1111 or 0000 or 1234. let me know what happens
Nov 25, 2008 | Motorola Mobility MOTORAZR maxx V6...
What is the 4 digit default lock code or phone lock of motorola L6???...
please e mail me... saltek_jim_ph@yahoo.com ....what is the default lock code of motorola L6.. im not talking about the 6 digits code or (000000)... example: when you want to lock the multimedia it requires 4 digit only... I already reset my phone.. (master clear and master reset) it requires the 6 digits code (000000).. I was expecting that the 4 digits code will be returned to default.. I tried (1234), (0000) and (1111 to 9999).. all I know is the default 6 digits code (000000) to reset my phone..
Feb 21, 2008 | Motorola Mobility L6 Cellular Phone
NorStar T7316E Corded Phone Problem - mailbox locked
You will need to dial into the system admin of the voicemail
Feature 983
the password is dependant on how many digits your extensions use. 1020000 for 3 digit and 10020000 for 4 digit, 120000 for 2 digit.
go through the screens
Mailboxes, modify, scroll to password and press change.
Will reset to 0000.
Dec 19, 2007 | NorStar T7316E Corded Phone
Locks & Locksmithing Logo
43 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
