Question about Dryers
Rear rollers squeek - Dryers
  • 126 Answers
Replace rollers ,idler pulley and belt available as a drum maintance kit thru wp
Posted on Jun 19, 2009
Amana lea30aw squeeks
there are drum rollers that support the drum and turn during rotation,FIRST UNPLUG the unit from POWER,then,remove the 2 bottom screws at the front cover and remove lower cover below the door, then remove 4 screws on front door cover 2 on each side and remove upper front and door,then remove 2 screws just under the top cover in front then release and remove drum belt from idler pulley by reaching under drum on right side by motor,then remove drum and 2 pulleys will be on rear of inside machine the other 2 will be on door panel,sometimes you can remove "c" CLIPS AND CLEAN HAIR AND LINT OUT AND lube with dry lubricant,but they are relatively inexpensive so replace all 4 rollers,check axles they turn on too and belt condition too amnd throughly clean out lint from innards too
Mar 11, 2012 | Amana Dryers
Loud squeeking noise when dryer starts and continues while it is drying
Greetings,
the belt pulley needs some lubricating..they squeek and the rollers thump...of coarse, its possible a stuck roller can squeek...The front needs to be removed..UNPLUG machine and if you have a removable lower access panel..this can be removed and lube the belt pulley.
if no bottom front., remove filter screws and raise top. there are two screws inside of front.Remove the front and you can lube or change parts as needed...
Jan 25, 2011 | Kenmore 66832 Dryer
I have a canon pc850 the roller is squeeking.
Wich roller?
If the sound is geting from drum unit, replace drum unit.
If sound is getting from bushings or axis apply small amount of wd40 or similar.
Jun 29, 2010 | Canon Office Equipment & Supplies
Dryer making a high pitched squeek, I took apart
I normally don't work on gas dryers but it sounds like the drum rollers are in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 27, 2009 | Amana LGA10 Dryer
Maytag dryer squeeks when I first turn it on. Started about a couple of weeks ago. Squeek would go away after a few minutes, however now it is continuous.
Hi, The most popular squeeling issue in the Maytag dryer is caused from the idler pulley. The idler pulley keeps tension on the belt. The next possible problem could be the 2 rear drum rollers. These rollers are fastened to the rear bulk head and they support the drum. The third possibility is the motor bearing. Usually, when the motor starts to squeel, the motor will shut off suring the cycle and will not restart until the motor cools down.
I would advise you to change the idler pulley as well as the rear support rollers. The cost for these parts are very costly and a little preventive maintainance goes a long way.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Dryers
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
Squeeking
The squeeking sound usually is in the fuser area
open the fuser roller area( clear paper jam the rollers are hot wait until it cools down get some spray silicone(similar to wd 40 with a plastic tube to reach small areas spray small amount on any e
xposed gears(plastic ) do not spray the fuser rollers
if you see nay other moving parts give them a light spray
turn back on and see if sound has stopped
If not try to determine when squeeking starts
then spary appropriate area
Dec 29, 2008 | Canon ImageClass D880 Copier
Squeeking
most common problem is a bad idler pulley and/or roller assy, you can order a repair kit for your dryer probly under $40, includes new rollers, belt and idler pully part number 4392065
Mar 23, 2008 | Kenmore 62822 Electric Dryer
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
Marvin
Marvin
