Question about Marvel (6SBARBSG) Wine Cooler
My light for my marvel wine fridge will not turn off?
I have a marvel under the counter wine fridge with a spring on off switch and for some reason the light will not go off even when the door is closed any suggestions?
    Novelist:
  • 101 Answers
There is also a light override ON/OFF button next to the door switch to allow the light to remain on for display setups. Make sure that switch is off. If it is off, then your door switch must be shorted out and should be replaced.
Posted on Sep 15, 2009
  • subdriver Jan 09, 2010
    Make sure the light override (used for display purposes) is off. It is the manual ON / OFF switch in the toe-kick next to the door operated (spring) switch.
    If this does not work, either the switches are wired incorrectly or the contacts have failed in the switch.
  • Anonymous Mar 16, 2017
    I could not find a switch to turn my light off, so I just unscrewed the little bulb in the ceiling. Not a good idea to leave it on as it actually gives off a bit of heat and fridge will be running overtime to compensate.
fridgetech
  • 473 Answers
SOURCE: Haier HVT12ABS Compact Wine
If the unit has an internal fan it would be ok to use it as a built in.
Posted on Nov 16, 2007
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
mikedurland
  • 481 Answers
SOURCE: door doesn't close automatically.
it sounds like you need a new set of door cams. they should look something like this. they mount on the bottom hinge and use the weight of the door to close it.2fe6866.jpg
Posted on Jul 27, 2008
  • 101 Answers
SOURCE: Marvel wine refrigerator running,but not cooling
If your unit runs but does not cool, you have a "sealed system" issue. Either you are low on refrigerant which would be evident by frost build-up near the area where the freon first enters the evaporator plate. (lower middle, then travels left) or the compressor has lost the ability to develop the necessary differential pressure. You do not want to run the unit like that...you can **** in contaminants that will harm the compressor if you already haven't. You should contact a servicer to get it repaired. If you are still within the warranty period you should contact the dealer you got it from to initiate service.
  • 101 Answers
SOURCE: Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Posted on Feb 05, 2010
Why does My marvel 61WCM wine fridge turn on but right away off again?
First make sure it is not plugged into an extension cord. Low voltage could cause this type of problem. If you have it plugged directly in ,It is probably the compressor or overload relay on the compressor. You can bypass the thermostat to see if it is the problem, by first unplugging the device, then removing the wires from the thermostat, and jumping them together. Then plug it in If it still acts the same way the problem is in the compressor or overload relay mounted on the compressor. Sometimes the relay can be purchased and replaced or a hard start might work solve your problem.
Aug 07, 2014 | Marvel 61WCM Luxury 45 Bottle Wine Cooler...
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
My marvel wine refrigerator runs loud.. How can I make it quieter
Pull the back panel and vacuum around the fan and condenser area. (Un-plugged... OF COURSE)...
Wipe the fan clean of all dust/dirt.
Buy those SMALL RUBBER carpet cups and put the under the 4 feet... and tape an ordinary sponge at any area that has direct contact with your counter... Thick rubber or felt.
There are actually "heater insulation" pads that can be purchased at your HVAC supplier... (but sponge or foam padding can work).
It is a compressor... you can only get it to be a little more quiet.
Hope this helps
Jun 24, 2014 | Marvel (6CAR) Refrigerator
My wine cooler door swicht is not working,light is on even with the door closed
The switch is bad. Two wire simple switch. Replace it. Un-plug before replacing.
May 05, 2014 | Viking VUWC140 Wine Cooler
CL flashing even though the coils have been cleaned. unable to reset wine fridge
To clear the alarm:
1) Press and release the "SET button four times. "cnd" will be displayed on the screen.
2) While "cnd" is displayed, press and hold the "SET" button. The display will show the number of weeks the refrigerator has been running.
3) While holding the "SET" button, press and release the ON/OFF button. The number shown on the display will reset to 0.
4) Release the "SET" key.
Jan 12, 2014 | Marvel 30WCM Wine Cooler
My marvel wine fridge door handle is loose.
Should be held on by machine screws, tighten them.
Feb 03, 2013 | Marvel Refrigerators
The door light in wine fridge will not turn off when the door is fully closed..
There is a switch for the light. If it isn't a mechanical switch where the drawers slide in, it will be a magnetic switch in the edge of the drawer
Dec 27, 2012 | Haier Aficionado 26 Bottle Wood Trim...
Other than temperature, is there any other reason not to store wines in a regular fridge? I don't mind my wines being slightly cooler and I can always leave them on the counter for 10 minutes bef
Aside from temperature, humidity is a major concern. The low humidity levels can cause the cork to dry/shrink allowing room for both air and other food odors to enter the bottle and tamper with the quality of the wine inside. Wine coolers offer an optimal humidity level of 50-80% needed to keep your wine in good condition.
Jul 31, 2012 | Furniture
Marvel (6SBARBSG) Wine Cooler Logo
1,662 people viewed this question
Top Marvel Furniture Experts
Sal De
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
