Question about Dewalt DW505 Electric hammer drills
Chuck removal on a dw505 - Dewalt DW505 Electric hammer drills
2 Suggested Answers
smjdragonfly
  • 79 Answers
SOURCE: Need a chuck for a 1/2
Go to DeWaltService net.com and look up your model and type number. Inside the chuck is a left-handed screw. torx (star) T20. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Please rate me
Posted on Jun 18, 2009
I have a DeWalt DW505 hammer drill. I was drilling into concrete and my bit came out. After several attempts to drill again, I noticed the drill chuck was not holding the bit. I opened the chuck all the...
Hi Ken, sadly it sounds like the chuck is past its best. The cogs inside the chuck have most probably worn. If you can get the chuck off try clamping it in a vice and use some pump pliers to undo it. Failing that you will need a new chuck which you may be able to get at a good diy store.
Sep 14, 2013 | Dewalt DW505 Electric hammer drills
We have a chuck that got jammedand broken, is it possible to remove the chuck only and replace it or do u only get the whole front section with chuck. And if the chuck can be removed, how do u remove it....
With the chuck open as far as possible, look within the jaws of the chuck for a bolt or screw head that attaches the chuck to the shaft. Remove the bolt/screw and remove the chuck. Some chucks can also be screwed onto the shaft, so look for signs of threads at the base of the chuck. Otherwise, once the bolt/screw is removed, tap along the outside around the chuck with a plastic hammer to loosen the chuck. Penetrating oil will help.
Take your chuck with you to a "big box" type hardware store, where a replacement should be available. Any well stocked hardware store should be able to help you. I have found that the somewhat smaller hardware stores are usually staffed with knowledgeable persons, and getting a replacement ordered is easier. One is more likely to be stocked in the larger stores.
The name brand of the chuck isn't as important for a replacement as is the correct shaft size and style of fit.
Best regards, --W/D--
Jun 15, 2011 | Chicago Pneumatic RP9790 STANDARD GRIP...
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I wanna change th chuck on my DW505 hammerdrill
if you don't have a screw in the spindle inside the chuck it will just unscrew. well, not just, you have to put a very large allen wrench in the chuck and hit it hard to loosen the chuck. doesn't sound right but that is the only way.
Aug 09, 2010 | Dewalt DW505 Electric hammer drills
Can't remove the chuck retaining screw.
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Bearing Removal
hi
use a puller bearing.
regards savumihai71
Jun 20, 2009 | Dewalt DW505 Electric hammer drills
Jun 16, 2009 | Dewalt 18 Volt Compact Drill Kit
Need wiring diagram for dw505-2 trigger
Here is your parts diagram just in case you need it.
http://www.ereplacementparts.com/dewalt-dw505-type-hammer-drill-parts-c-1009_9661_2281.html
And here is the number to a factor tech which could answer your question on trigger wiring. There is no diagram available but, I'm sure a tech will get you up and going.
(702)889-6025 ask to speak to a tech.
Mar 31, 2009 | Black & Decker Dewalt No.DW505 Heavy Duty...
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Dewalt DW505 Electric hammer drills Logo
81 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
