Question about gmail.com
JasonRake2469 Need test results
If I get blood drawn in new Hartford ny lab corp where is it tested and how long before my doctor gets results
I am not familiar with this lab. Here, the results for the most common tests are available in 1 day and a week if the less common tests need to be done in the city.
Feb 25, 2017 | Health & Beauty
Generator running but no voltage
You need to run these tests in the video and come back to us with the results. Send your test results to us here:https://www.generatorguru.com/ask-the-guru/
Then we can tell you what the problem is :)
https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
If you need parts we sell them here: https://www.generatorguru.com
Feb 22, 2017 | Electrical Supplies
Power horse 9000 will not generate power
You7 need to run these tests in the video and come back to us with the results. Send your test results to us here: https://www.generatorguru.com/ask-the-guru/
How to test your Electricity Generator AVR Brushes and Alternator on...
Feb 10, 2017 | Electrical Supplies
Why does my Dell Dimension E310 w/XP Home Media. Locks up shortly after booting?
It's a memory faulty -- not a hard drive error. Move the DIMM to the other socket (or swap it with the other one if there are two). Re-test. If the error follows the DIMM, the module is bad - replace it with a new one. If the memory occurs with the other module in DIMMA, it's the socket that's bad and you'll need to replace the system board.
Aug 05, 2014 | Dell Computers & Internet
Will the result of my pregnancy test change after time? If it was positive and then fades, does that mean that I am not pregnant?
The results are stained onto the test, so even though they may fade a little over time, the results will stay as they are. If you got a positive pregnancy test result - then you are pregnant.
Mar 04, 2013 | Health & Beauty
How do I read the result of my pregnancy test? I am getting so stressed about it that I just cant understand the instructions.
Not all pregnancy tests are the same but there are usually two ways of getting a positive result:
1) Some tests just show a clear vertical line in the control window and if you are pregnant you will also get a clear vertical line in the result window.
2) Some tests show a vertical line in the control window and a "-" sign in the result window if you are not pregnant and a "+" sign in the result window if you are.
All pregnancy tests come with instructions and usually they have pictures explaining the results. You can probably hold your pregnancy test alongside the leaflet if you are confused and it should clarify the result for you.
What is a color changing tip on a pregnancy test? Is that where you get the result?
A color changing tip that comes with some of the more expensive home pregnancy tests is just an extra way of showing the user that the test is actually working. The actual result of the test appears in the result window - you have to read the specific instructions to be fully sure how a positive result will appear on that particular test.
How long do you have to wait for a home pregnancy test to give a result?
Most home
pregnancy tests give a final result within 2 minutes of coming into proper
contact with the urine flow.
I can't get an inspection sticker for my car because it keeps failing inspection because the computer will not reset. Every time it does the same thing. When they test the OBDII Readiness it says the...
Every time you reset the light or disconnect the battery it completely resets the system and it has to go through EVERY test again. The O2, EVAP, and Cat tests are generally the LAST THREE tests that are tested. You're not doing yourself any favors here.
Essentially what these readiness monitors are is the computer's notation that his has run the self diagnostics on each system and that the results feel into the expected results. If it is outside the expected results the computer will generally try to run the test multiple times before setting a DTC and turning on the Check Engine Light. It cannot set the status to "Ready" until it has a successful test within expected results; sometimes multiple successful tests. Sometimes, the tests need to run at different speeds - so the vehicle has to be driven not only at freeway speeds, but also city speeds for the tests to complete properly.
The O2 test MUST complete before the Catalyst test can run. The EVAP test generally requires that you have your fuel level at between 1/4 and 3/4 and that the vehicle sit undisturbed after being driven for a period of time for no less than 8 hours in order to run the EVAP test.
The same can be said for the O2 test sometimes because the computer needs to test the O2 sensors reaction to heating up and cooling down. Eventually they will all complete - unless there is an issue. I have seen where a component was in the process of going out and the computer was getting both GOOD and BAD results when running the tests. As a result it wouldn't set ready status because it wasn't getting the concurrent GOOD test results.
As a Texas Recognized Emissions Repair Facility - my shop sees this kind of stuff all the time.
Good Luck.
Jun 01, 2011 | 2006 Mazda 6
DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
It sounds like you may need to Update the Drivers. If not you may have a Bad Sound Card.
Jan 22, 2009 | Computers & Internet
gmail.com Logo
37 people viewed this question
Top gmail.com Computers & Internet Experts
Robet
Robet
Richard Solanski
Richard Solanski
Level 1 Expert
Are you a gmail.com Computer and Internet Expert? Answer questions, earn points and help others
