Question about PC Desktops
Warranty extention Have a emachine D4362. DOes the ext warranty cover the motherboard, hard drive, etc. PLease specify clearly. Thanx, Lee
  • 1,601 Answers
Re: Warranty extention
It looks like that is the case. Here is what I pulled from thier website. Extended Service Plan (ESP)There's no doubt that your purchase was designed to give you years of use, however, an unexpected breakdown can mean serious "parts and labor" or replacement costs. Protect your investment by purchasing one of our new and improved Extended Service Plans! Benefits include:
• 100% coverage on Parts and Labor - with no deductible or hidden fees.
• Power surge protection for notebooks.
Extended Service Plan options for Desktops:
2-Year Desktop ESP 3-Year Desktop ESP Upgrade to:
2 years warranty on parts and labor
2 years technical support*
On-site service
Only $99.00 Upgrade to:
3 years warranty on parts and labor
3 years technical support*
On-site service
Only $139.00
Extended Service Plan options for Notebooks:
2-Year Notebook ESP 3-Year Notebook ESP Upgrade to:
2 years of screen repair or replacement
Only $109.00 Upgrade to:
3 years of screen repair or replacement
Only $189.00 Please note: Extended Service Plans may be purchased up to the end of the 12th month (364 days) from your desktop PC original purchase date. The extended warranty option is not available for all products/models. Refurbished units do not qualify. ESP coverage must not exceed a total of three (3) years from your date of purchase.
To Purchase an Extended Service Plan
You can purchase an Extended Service Plan by phone or online chat. You will be required to provide a credit card number and other requested information.
Live Chat Support—available 7 days a week, from 3 am to 12 midnight (PST)
Live Chat now features a new suite of tools that will allow our support agents to assist you more efficiently. With your permission, our representatives can now view and take control of your computer, check your system parameters and provide you with web pages to resolve your technical issues.
Posted on Nov 02, 2007
0 characters
3 Points
Diagram emachine wiring
There is no specific wiring for eMachine. your wiring goes from power supply (big box with fan) to motherboard (large board with many components) to hard drive, cd rom, fan, etc. pretty easy to figure out if you look closely
Jun 25, 2013 | eMachines T5274 Desktop PC
Emachine dvd writer not showing on my compter and cant find a driver on...
If u loose your dvd drive quites working and all it does is spin and flash lights turn off the pc and open it if you have warranty dont do it call the warranty number because if you remove the sear the warranty is void but if your like me and dont care then check the seriall cable with the side that connects to the mother board checki to see if its not loose some of these cables where manufactured wrong so they dont lock into place replace it or turn it upside down where the blue cable is at the top bring the dvd writer down one slot if it has a thin metal plate covering the bottom expansion bay remove the metal by cuting it with pliers or do it by hand bring the player down and use the the nesxt serial port cable so you will have the blue at the top not being used.
on Jun 20, 2008 | E-Machines eMachines Desktop PC
Emachines D4362 starts only after many button pushes
Sounds like you might have corrupt window system files or the machine might not be recognizing the hard drive.
Press the DEL button to go into the BIOS. Go to the section that shows you the hard drive. If it doesn't show you a hard drive model and shows none then your hard drive is bad and would need to be replaced. If your hard drive is recognized in the BIOS then you'll need to try and reinstall windows. If you can't get windows reinstalled then the hard drive is bad at that point as well.
Jan 18, 2012 | E-Machines eMachines Desktop PC
Have no sound on my computer
first if your motherboard is in warranty then call the service center or else upgrade it to new motherboard , do not try your self to fix it because it could terminate your warranty or can ruin other things as motherboard is very delicate product
Sep 01, 2011 | E-Machines eMachines Desktop PC
I have an eMachines ET1810-01 PC Desktop. After a power outage, the computer won't turn on. When I press the power button to turn on, I see it supplied for about 5-6 seconds and off it goes. During this...
same thing happened to me with this machine -- actually, two power outages. I thought I was protected, as I run UPS and the machine should have hibernated (I know it did the first time). At any rate, after the first failure, the clock wouldn't run right, and after the second, the exact thing you describe happened.
I was within days of losing the warranty, and sent the box back. Cost $27 to ship, insured. They replaced motherboard and reformatted hard drive. It works fine now. 90-day warranty on the repair.
In short, your motherboard is toast.
Oct 29, 2010 | eMachines ET1810-01 PC Desktop
Emachines pc keeps saying hard drive is failing
What kind of resources are you pulling on the pc everyday? For example are you doing heavy writing to the drive everyday such as video editing, ripping etc and how much air flow is your pc getting. If the case gets too hot or warm for long periods of time it can cause the hard drive to fail quickly. Lastly check your power supply male sure its pputting out the proper voltage to the computer specifially the connection to the hard drive. If its not stable the nit will cause your hard drive to fail.
May 25, 2009 | eMachines W3619 PC Desktop
Emachine crash
Yes, with that beeping sound that you're hearing from your hard drive is a sign of a bad hard drive , that's also the reason why the computer wont even boot because the hard drive is already bad, the best thing that you can do here is to get a new hard drive..
Hope that helps..............
Sep 12, 2008 | E-Machines eMachines Desktop PC
Emachine t7242
The ticking sounds like it could be your hard drive failed. The computer is not making any beeps or anything? just the ticking? If the pc is under warranty I would definetly handle it that way. If this is not the answer you are looking for please disregard.
Good luck,
Jun 13, 2008 | E-Machines eMachines Desktop PC
Emachine T5026 installing a new hard drive.
place the harddrive over or under the old drive.
a IDE cable most be connected to the harddrive and to the motherboard.
and a 4-pin power cable most be connected.
May 18, 2008 | E-Machines eMachines Desktop PC
PC Desktops Logo
138 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
