Question about Cycling
Mongoose Ledge 2.1 pedal thread size
I want to replace the pedals on a Mongoose Ledge 2.1 26" MTN bike. Its a relatively cheap bike so I don't want anything too expensive and I am unsure of the pedal thread size. I know 9/16" is standard, I also know some cheaper bikes use 1/2" and since it is hard to get an exact measurement from the thread itself I need an answer. Between the pedal thread and the crank hole it could measure either way. Anyone know for sure, I want to buy the right size the first time. THANKS!!
  •  Robert
    Robert Apr 23, 2014
    I would have to buy either a caliper set or a micrometer to do it. Its too colse to call with a tape measure or ruler. Thanks though, if i had the tools avalible it would be done.
    Problem Solver:
  • 7 Answers
Measure the threads on the crank. Use or borow a pair of calipers. Measure with two threads as the outside edges to get proper diameter.
Posted on Apr 23, 2014
  •  Robert
    Robert May 07, 2014
    I will answer my own question here, 9/16" is the thread size. The obvious part i missed was my bike has a 3 piece crank. While not always the case a 3 piece crank usually uses 9/16" pedals, while a 1 piece crank usually will use 1/2" pedals. I did say usually because there are exceptions, but in this case it holds true. Thanks!
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: What are the threads and
The make of the bike does not define the crankarm on it which might define the spec of the threaded hole.
A simple web search for "bicycle pedal thread pitch" leads to..
http://www.sheldonbrown.com/gloss_p.html
Look for "pedal threading"
Posted on Aug 19, 2011
What is a decent replacement rear derailleur for a Mongoose 26" Ledge 2.1 Mountain Bike?
Get the kind that has a lever shift instead of the grip shifter. The plastic part that holds the spring breaks easily. The lever shifter has been going strong on my bike for 6 years without a problem
Aug 31, 2016 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
There are no threads on the crank arm to screw a pedal on. What do you do now?
1. replace the crank.
2. Purchase a Heli-Coil or other brand at an auto store. It looks like a tube with threads on both sides that will screw in to the stripped hole and there by install new threads. Bring the pedal to the auto store to make sure it will thread in to the "female" threads on the Heli-coil.
The problem is the pedal is steel and the crank arm is soft aluminum. Also, people damage them because one pedal is normal thread and the other is reverse thread meaning you turn clockwise to loosen.
Jul 29, 2014 | Mongoose 26" Mens XR-75 Mountain Bike
Stripped bicycle pedal
Better replace the pedal and most probably the crank arm as well. Sometimes a new pedal can cut the threads true again on the crank arm but the crank arm may need replacement too, depending on the damage. Remember to fit the correct side pedal. The pedal threads differ between left and right and pedals are usually marked "L" or "R".
Jan 04, 2014 | Huffy 26" Womens DS-7 Dual Suspension...
They stole my bikes pedals and I want to know what size they are to buy them?
Being a mtn bike it probably had flat pedals or lock-in SPD. Either way, pedals dont come in sizes, the shoes do. A pair of pedals will fit ANY bike, just select the type you want. Just be careful when screwing on, there is a LEFT PEDAL and a RIGHT PEDAL. They screw on in oppposite directions.!
Mar 29, 2013 | kawasaki 73026-9 KDX126FS Dual Suspension...
I need to know what kind of crankshaft does a mongoose men's melee have?
Ya mean BOTTOM BRACKET? Probably something at the low end of Shimano. They don't publish the minutae for their department store bikes.
You could ask Mongoose directly or take it your Local Bike Shop and have them determine the answer (which is recommended in Mongoose's manual if you want service on a 3-piece crankset anyway).
http://www.mongoose.com/usa/usaeng/mtn/man_inst
http://www.mongoose.com/mtn/ask-mongoose
Sep 21, 2011 | Cycling
I have 26" Mongoose Snarl,both
A simple web search for 'remove bicycle crank' turns up numerous videos.
http://www.parktool.com/blog/repair-help has the many special tools and advice one needs to work on a bike.
Aug 21, 2011 | Mongoose Sector 26 Men's Full Suspension...
What are the threads and pitch for a Mongoose Mtn. bike pedal - Right side?
Aug 19, 2011 | Cycling
Determining pedal size for 26 inch schwinn mirada bicycle and compatable upgrade pedals
This write-up explains it in detail.
http://www.sheldonbrown.com/gloss_p.html#pedal
Search the page for "Thread sizes".
As far as upgrade pedals go, that would depend on the rider's preferences (toe straps, clipless) and comfort level with them. A Bike Shop will probably stock and install anything you could want.
Keep in mind that the left side is left threaded.
Dec 26, 2010 | Schwinn Cycling
Clicking sound when pedal
Dry or bad bearings in either the right pedal or the bottom bracket (shaft between the pedals).
See this article, particularly the paragraph, "Symptoms of a bottom bracket needing overhaul"...
http://en.wikibooks.org/wiki/Bicycles/Maintenance_and_Repair/Bottom_Brackets/Bottom_bracket_overhaul
Jul 17, 2010 | Pacific International Mongoose 26" Men's...
Cycling Logo
147 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
