Question about Mitsubishi SELECT WL639U Rear Projection Television Replacement Lamp RPTV
Wl639u optical engine - Mitsubishi SELECT WL639U Rear Projection Television Replacement Lamp RPTV
How about Fuzhou Antyco Optics CO., Ltd?
Fuzhou Antyco Optics Co., Ltd. is a professional manufacturer of crystal and optical components in the photonics industry. Antyco owns standard factory, advanced fabricating machine including Spherical Milling Machines, CNC Plano Milling, High speed Polishing, Precision Polishing, CNC Grinding and Polishing, Coating Machine, Ultrasonic Cleaner, etc.. The strong and steady growth have lead us to a very skilled team of fabricators, mechanical engineers, process engineers, optical engineers and coating designers, which successfully provided the advanced technical solutions and satisfactory products for different areas of the numerous customers.
Our manufacturing capabilities consist of all types of customized lens, Beam Splitters, Polarizing Optics, Prisms, Filters, Coatings, Optical Systems, Optical Assemblies and Optical Systems Solutions, Laser Crystals, NLO Crystals. The products are widely used in laser industry, optical communication, laser display, medical equipment, survey equipment, precision Instrument and semiconductor. Optical elements of various materials can be processed in Antyco: zinc selenide(ZnSe), zinc sulfide(ZnS), calcium fluoride(CaF2), barium fluoride(BaF2), silicon(Si), germanium(Ge), YAG crystals, YVO4, sapphire, quartz glass, optical glass, ceramics, cooper, aluminum, etc.
with the strict quality management system, Antyco got the ISO 9001:2000 Certificate. Today, over 60% of Antyco products are exported to USA, Japan, Germany and other European, Asian Market. Looking ahead, Antyco will continue to deliver customers with reliable quality, competitive price and on-time delivery products.
For more: http://antyco.com/
Sep 26, 2016 | 2007 Toyota Camry
Large red spots growing in the middle of my 50v500 hitachi projection LCD screen
Hi, you have an Optical Engine fault. Complete assembly needs to be replaced. This page shows the most common Hitachi Optical Engine Faults.
Hitachi LCD TV Light Engine Optical Block Info
Nov 27, 2015 | Hitachi Televison & Video
Two bright blue half circles on bottom of telivision Sony LCD projection set
YOU HAVE EITHER A DEFECTIVE OPTICAL ENGINE ASSEMBLY OR THE OPTICAL ENGINE IS JUST DIRTY INTERNALLY. IF YOU CAN TURN THE TV OFF AND STILL SEE THE BLUE SPOTS AFTER THE VIDEO GOES AWAY THEN IT WILL BE DEFECTIVE OPTICAL ENGINE IF NOT THEN IT IS MOST LIKELY DIRTY OPTICAL ENGINE.
Dec 17, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Have green cast to picture, what's up?
Hi:
Unfortunely the optics engine is faulty, one of the small LCD inside the light engine is coming apart. The only fix for this problem is to replace the optics engine, most call it Light Engine. You can get one fairely cheap from this site. COM">WWW.TRISTATEMODULE>COM . They sell optics engines new or rebuilded ones.. They will even repair yours..
Nov 10, 2010 | Hitachi 50V720 Television
Mitsubishi DLP W62627 displays lotsof yellow and blue...color is not right, although picture seems ok do I need to replace lamp or is it more ??
Try to reseat the DVI cable between the chassis and optical engine. If this doesn't fix the problem, you will have to replace the optical engine. The lamp is not causing this problem. A new optical engine can be pricey. You would have to get it from Mitsubishi. $450 + $300 core charge. You do get the core charge back when you send in the bad optical engine.
Optical Engine Part Number:
938P017020
Oct 07, 2010 | Televison & Video
Greenspots on screen
sounds like its your optical engine block. if it starts to leave green spots or white dots that keep on coming then its your optical engine. let me know I know someone who repairs the optical engine block. leave a rating after you find out.
May 08, 2010 | Panasonic PT-52LCX65 44" HDTV
What is the difference between a light engine and optical block?
Light Engine and Optics Block is same thing, main part of DLP TV and multimedia projector to produce and project image on front screen.
Few manufacturer call it light engine and some says it optics block.
Nov 09, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand Wega corners are blue
Hello Wealth744:
The problem is that your LCD optics Engine is failing. There are three small screens much like the size of a nono Ipod screen, inside of the optics engine. Each one a different color Red, Green, Blue. The blue lcd screen is faulty.These can be replaced but labor to do this is intensive and most tech will want to just replace the optics engine. So in short the Optics Engine need to be replaced to correct this problem.
Sep 22, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Not a problem - just clarification
They are the same part. Sony reffers to it as the optical block, while other manufacturers call it the light engine.
May 16, 2009 | Sony KDF-E42A10 42 in. LCD Television
Optical engine for akai pt50dl14
Here's a link to order the original Akai light/optical engine for this model (PT50DL14) from a major parts distributor:
Akai Samsung PT50DL14 Replacement Part Light Engine / Optical Engine Block
Feb 17, 2009 | Televison & Video
Mitsubishi SELECT WL639U Rear Projection Television Replacement Lamp RPTV Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
