Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
WD Passport not recognized
My device was working properly, and then suddenly was not recognized. I've tried to change data cables, hook up to other machines, and recover programs with no luck. The drive is running because I hear it humming and the blue display appears to be blinking in a faint way. I'm trying to figure out the best way to save my data before I go from bad to worse.
I added my WD Passport 80 GB it was seen in My Computer one day then i tried it again and it doesn't appear it on (humming and the blue lights on to) but still no WD Passport (F:\Removable disk) please help
Posted on Jul 03, 2009
When i connect my passport the computer recognizes it,but then it ejects itself form my computer. sometimes the start screen appears, then it ejects itself. please help
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 25, 2010 | Western Digital WD Passport 250GB Portable...
My wd smartware has suddenly stopped working. it shows not working checking for solutions... and then fades off. connecting my wd passport essential 500gb...i can unlock the hard drive to see the...
* the USB cable
* the power-adapter
Nov 21, 2010 | Western Digital My Passport Essential...
USB device was not recognized
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Jul 06, 2009 | Western Digital Passport WDXML800UE...
Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
Feb 17, 2009 | Western Digital WD Passport 250GB Portable...
Ibm t43, xp pro won't recognize my WD 320 passport
Well, that IBM is from 2004, the usb port and drivers is to old for the WD 320 who requries USB 2.0. Thats why your IBM dosent recognize it, your IBM getting wrong signal from the WD thrue the old usb port.
I dont think you gona make those items to work properly togher M8, sorry
Nic
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I had the same issue. Its not a power issue because it shows up in device manager. Heres what I did.
Right-click on my computer and click Manage>Disk Management
Your drive should show up there. Right-click on it. If explore is not grayed out, assign a drive letter to it and you should then be bale to see it in my computer.
In my case explore was grayed out. I had to click on the option to format the drive. After re-formatting the passport explore was available. I then assigned a drive letter to it and I have access again.
I guess somehow using it on multiple computers srcewed up the file-system on it. I was using it between windows and linux.
This fixed my problem.
Oct 28, 2008 | Western Digital Passport WDXML800UE...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Can I use my passport essential 2.0 to backup my work computer as well as my home computer?
You can use your WD Passport to sychronize data on multiple computers, you just need to set up the other computer name (e.g. "Work computer")using the software.
WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a
backup drive; it is NOT !
As per the documentation with this device:
"synchronization software is intended to synchronize the data from a
computer to the drive (WD Passport) and SHOULD NOT be used as backup
software. To use this software properly, we advise that you do not wipe or
erase the data from the internal hard drive (computer) and resynchronize, as
this will cause the data that WD Sync stored to the Passport to be deleted."
This is why you are hearing so many people saying that they are deleting the
WD Sync software, reformatting, and using the WC Passport as a true backup
drive where you can actually see the files that you are backing up, rather
than a bunch of unrecognizable sync files that likely don't have all the files that you thought you "backed up".
Aug 03, 2008 | Western Digital Passport WDXML800UE...
WD Passport not recognized anymore
Change your USB cable, I had same problem...changing the USB cable woked for me.
Jul 30, 2008 | Western Digital Passport WDXML800UE...
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Jul 29, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
1,700 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
