Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Black screen power indicator goes to flashing after 2-3 minutes press menue window says test good and other window says wrong resolution
Press menue button window says test good other time a window says wrong resolution
SOURCE: samsung 710v test good
For anyone having this problem i suggest to get a manual from asnerejas. His notes helped me out totally.
Its not something you would spot looking at its inside...
Posted on Apr 30, 2009
chanddra2009
  • 615 Answers
SOURCE: Brightness indicator windows does not go away
Dear sir This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Have a Nice Day
Posted on Sep 18, 2009
prashanthcl
  • 460 Answers
SOURCE: samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Posted on Nov 13, 2009
SOURCE: screen goes black
what to do when screen goes black and says analog
Posted on Dec 17, 2009
Starworx
  • 4 Answers
SOURCE: my monitor 940n samsung syncmaster gone in black...
I have just had this same problem. The problem mostlikely is a blown fuse on the inverter board. Mine was blown on the board and also a Capacitor (470nF/25V) was bad beside the Fuse.
I replaced both and monitor is working now again. After install the picture was a little grainy with little artifacts. In another post i found that the Power Supply board needs to be cleaned for unwanted residue. After that picture was fine again.
BEWARE that you need a soldering iron and a steady hand to replace these parts. If you are unfamiliar with soldering at all have an expert take a look at this. The Power boards uses 220v so DO NOT connect it to the Power when opened.
Starworx
Graphics drivers windows 7
Right click on the desktop and a pop up menu will appear. Three items off the bottom select 'Screen Resolution' and click it. A new window will appear, in the centre are 4 options, choose the drop down menu (small black triangle) against Resolution. It will most likely be showing 640x480 in the window. Click the drop down menu and select your required resolution, the best one for your video card will have (recommended) against it. Click OK and wait for your screen to refresh. You should see a confirmation message asking to OK the change. If you do not see that DO NOT TOUCH any keys or buttons for a minute or so. If the screen went black and stayed that way you have chosen the wrong one. By leaving the keys alone for a minute, the display will automatically revert to the last setting thereby giving you the option to try a different setting. If you touch anything whilst the screen is black you may not see anything again, be warned!
Dec 21, 2013 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
GeForce 9400 gt, black screen problem
It looks like your graphics card changes the screen resolutions and/or refresh-rate to something beyond your monitor's capabilities.
After installing the drivers and the screen goes black, restart you're computer and press F8 to get the Windows advanced menu boot and choose "Enable VGA Mode".
When booted into Windows, right click on the desktop and select "properties", select the tab "Settings" and pick a really low resolution like "1024x768" and press the "Apply" button (but don't reboot yet when asked to). Next press the "Advanced" button, then select the tab "monitor" and change the monitor resolution to "default" or 60Hz.
Now restart your system and see wether Windows will boot normally. If so, you can change the resolution and refresh-rate back to you preferred values. Whenever you pick a too high resolution or refreshrate the screen will turn black again, but don't worry, don't press anything and just wait 15s, after which Windows will roll back to the previous setting ...
Aug 16, 2009 | Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Screen goes black after 2 seconds
Simplest solution may be the screen resolution settings are set higher than the monitor's capabilities. Try lowering the screen resolution and refresh rate in the display properties or try booting to safe mode (press F8 when the Windows splash screen first appears) and see if the LCD will display the windows desktop. It that works, check your video drivers and the screen resolution and refresh rate settings.
If the monitor has the problem in safe mode and/or if lowering the screen resolution and refresh rate don't help then I suspect the a problem similar to one some Dell 17inch LCDs have. On the Dells It is usually caused by a defective voltage regulator transistor in the backlight inverter circuit. Troubleshooting that problem should only be attempted if you have experience at repairing electronic circuitry since it will involve testing individual components and soldering.
Jun 15, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Acer AL1511 15" monitor Screen Menu Problem
What operating system do you use? If it is a windows OS press F8 while the system is booting to access the Boot Manager, choose to boot to last known good configuration and if this does not work retry but select safe mode and change the resolution back to the previous one.
Jan 19, 2008 | Acer AL1511 15" LCD Monitor
Polaroid LCD TV TLA-4641C
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Aug 15, 2007 | Akai CFTD2052 20 in. EDTV-Ready LCD...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
42 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
