Question about Tool Force A-C1 50 PSI 2-in-1 HVLP Spray Gun A-C1
Need a manual for a Tool Force A-C1 50 PSI 2-in-1 HVLP Spray Gun
How do you take this hvlp gun apart for proper cleaning of the spray gun?
I've found over the years the least amount of times you can tear a spray gun completely apart the better. Usually a real good 'flushing' with lacquer thinner will suffice. I will take the air cap off and let it soak in thinner to dislodge any build up but other than that, I simply run thinner thru till it runs clear out the tip.
I also 'back flush' which involves having thinner in the cup and the air supply hose attached. the air pressure should be adjusted quite a bit lower than what you use for spraying paint.
Then you place a clean shop towel or rag over the air cap of the gun and pull the trigger. This forces air back into the paint cup 'back flushing' the gun. Then take the rag away from the cap and pull the trigger again to run thinner thru the gun the normal way.
IF you still want to tear the gun apart for cleaning you can hopefully get some idea with this video link;
Quick Easy Way to Clean HVLP Spray Gun
Hope this helps.
May 25, 2015 | HVLP Air Tools & Compressors
Part needed for TOOL force spray gun
la lumiere dans le dash est allumer check engine
Jan 31, 2014 | Tool Force A-C1 50 PSI 2-in-1 HVLP Spray...
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
Hey yall i got a sharpe finex3000 hvlp spray gun model sh-880 1.4 finish gun. and ive used this gun before and i cant remember how 2 set it up etc or what the best working pressure is. anyways i was tryen...
There is a step by step description in the manual of the Finex3000 itself (incl. pressure set-up, etc...). In case you don't have it anymore, you can look online: http://sprayfinishingstore.com/manuals/
Jul 25, 2011 | RTO Sharpe Finex 3000 Hvlp Gravity Auto...
I need a kobalt hvlp spray gun manual where can i get one?
Go back to where you bought it and have them photocopy the book from another unit. Good luck!
Jun 19, 2010 | HVLP 10 Piece Hvlp Paint Spray Gun Set
Bad air flow. it doesnet seem to be spraying out of the fan correctly. In fact, i don't even get a noticable fan spray. it just sprays a round pattern no matter what i do.
Check none of the air holes int he cap are blocked. Also there is a small wheel adjuster on the left side of the gun, or perhaps even on the top which will adjust fan spray shape.
Of course you need about 30-40 PSI pressure at the gun end for it to spray properly, as well as a compressor with about 12-15cfm air flow rating to use a HVLP gun efficiently.
Apr 16, 2010 | Sharpe Manufacturing FX300 HVLP Spray Gun...
Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
IS GTi W GRAVITY SPRAY GUN A HVLP GUN?
It depends on the air cap\tip you are shooting with. For instance the 110 air cap is a standard compliant style. Were as the 105 and 115 are a HVLP style.
Aug 06, 2009 | GTI Millenium Hvlp Gravity Feed Spray Gun
Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Feb 09, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Tool Force A-C1 50 PSI 2-in-1 HVLP Spray Gun A-C1 Logo
52 people viewed this question
Top Tool Force Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Tool Force Air Tool and Compressor Expert? Answer questions, earn points and help others
