Question about Hitachi 53FDX20B 53" Rear Projection Television
Image is very dark and hard to see. - Hitachi 53FDX20B 53" Rear Projection Television
Dark shadow in lower left of screen
i guess there is some problem with your panel. make sure you show it to the nearest service centre
Jul 22, 2013 | Toshiba 37HL67 37 in. LCD HDTV
Dark screen on R530, can see image with bight light?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 14, 2012 | Computers & Internet
Picture looks yellow
The image settings has changed it may be in sepia.. Just change it in camera setting or image setting into auto or normal ,,
Jul 15, 2012 | Akai PTH5498 54" Rear Projection...
Image is too blue when dark images can hardly anything already mentionned
image is too blue means that it is missing its green and red stream. On your response, be more specific as to what the problem is, what type of tv, etc.
Jan 23, 2011 | Televison & Video
The image looks dark
The finished image looks dark or it looks dark in the viewfinder?
If your question is "the image looks dark" in the viewfinder my answer is it's an F4.5 lens so letting less light into the viewfinder and it will look dark. The big difference will be seen if you are coming from lets say a Nikon 50mm F1.8 which is two stops faster then your F4.5.
If it's the finished picture after you taken it I'd say you underexposed the shot.
Dec 10, 2010 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
ThinkPad T21 dark monitor. What part to change?
seems like a bad inverter that needs changing
Jul 03, 2009 | Computers & Internet
The screen went dark on jmv 111
Dark as in gone or dark as in the image is still viewable?  How does the onscreen menu look when the image is dark/gone?  If the onscreen menu looks right and the image is still dark, you might want to check the cables or another input.  If another device using different cables and another input looks fine, you may only have a problem with the input/cable you are using to view the movie.  If the onscreen menu is also dark, then I would think there is an internal problem that needs looking into.
Mar 23, 2009 | Jensen Car Audio & Video
My d40 has a image in viewfinder, will not take picture.
What lens are you using with the D40? Is it an AF-S lens? And is the Mirror Lockup on? Chech the Custom Settings menu. If mirror lockup is on, turn it off.
Feb 14, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Hitachi 53FDX20B 53" Rear Projection Television Logo
22 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
