Question about Logitech QuickCam Express Web Camera
Does not work on messanger
My webcam works to take pictures and video, but when I chat on messanger and try to start a video conference, I get the message that the device is not connected. However, it is connected just fine for taking pictures outside of messanger.
  • 8,637 Answers
Re: Does not work on messanger
Normal 0 See section C. Windows Live Messenger in the info below.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype ( ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger ( ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 23, 2009
0 characters
3 Points
What could cause my webcam to be blurry?
Whether your holding a video business conference, having a personal video chat with a friend or recording video with your laptop webcam, image clarity plays a huge factor in the quality of the video. There are a number of factors that contribute to the image quality, including available lighting and screen resolution settings.
Adjust your webcam settings, such as brightness contrast, hue and saturation to accommodate the lighting in the room. In order to access your webcam settings, click on "Start" and open the "Control Panel." Choose "Hardware" and then choose your internal webcam from the hardware menu. Select the "Properties" tab to open the setting controls and slide each bar until you achieve the ideal visual settings for your broadcast. Increase the available lighting behind you when conducting a webcam chat, but do not increase the lighting close to the webcam. A lack of back lighting not only creates a darker image projection, but can cause graininess. Too much light close to the webcam can blanch the image, making it difficult to see. Adjust your screen resolution. When the image quality is blurred and distorted during a webcam broadcast, lowering your resolution can sharpen the image projection. To lower your resolution, right-click on your desktop and click "Properties." Choose "Screen Resolution," from the available prompts. Lower the screen resolution one step below where it is currently set and test the image quality. If it needs further sharpening, repeat the process until you achieve the desired clarity. Adjust settings in the video chat program you are using. For example, if you are using Skype, select "Tools" and click on the "Video" icon in the left toolbar. Select "Webcam Settings" and adjust your visual and camera function settings, such as the hue and saturation, as well as lighting compensation. Test your bandwidth settings. If the traffic on your network is high, and multiple users are sharing the same Internet connection, it can affect your bandwidth and lower the quality of your video projection. In order to conduct a quality video session, you should have minimum bandwidth connection of 128 kbps. To check your bandwidth, visit an online test site like SpeedTest and run a bandwidth check. Dust off the lens to free dust particles with an air can. Dust particles can cloud the clarity, but you don't want to wipe them away with your fingers or a rough cloth. Blasting the lens with a burst of canned air will blow away debris and help improve picture clarity.
Jan 30, 2013 | Logitech QuickCam Ultra Vision Webcam
Help meee
tell her to properly set the webcam
1 tell her to install yahoo messanger and u also install it then create yahoo account both of u then log in with that account to yahoo messanger then plugin the webcam to see ur video then go to action menu on yahoo messanger and click on view my webcam then broadcast ur video. then properly configure ur audio as well as video settings in the yahoo messanger then u invite ur friend to view the cam she will be able to see u as well as u will be able to see her...... then enjoy ur big chatting hours... happy chatting
Sep 05, 2009 | Microsoft LifeCam VX-1000 Webcam
The sound works well but the camera is not. I can see the caller but they cannot see me and there is no inset picture of me as there used to be when making a video call
can u see ur video on the screen. if yes then properly configure ur video conferencing software and u will be certainly able to broadcast ur video to the caller. download yahoo messanger and then create a yahoo account and log into yahoo messanger. then plug in the cam and go to action menu and then click on view my webcam. u will be able to see the video on the screen. call any one who has cam and u can see his video nad that person can see u and can hear u if u have microphone with u....then happy video chatting
Sep 05, 2009 | Logitech Quickcam Chat Webcam
Video conference with 4 people split screen
I have looked into this for quite some time...what if you get a lot more features in another software...!!! ooVoo is the software and you can use 6 people video conference with recording facility. The problem is Windows Live messanger has some technical issues when it comes to multiple video conferencing...hence ooVoo is for you. Download from here.. there's a free version and trial version giving you full access for 30 credit card required. There are other softwares but they are cheap I suggest you to go for this one.
Aug 05, 2009 | Logitech QuickCam Pro 9000 Web Cam
I want to connect with 3 people via Logitech webcam. Tried last night and it did not seem possible. Can you give step by step instructions?
Skype's answer:
Video calls are only possible with two participants. Unfortunately, video conferences are not possible at the moment.
Jan 03, 2009 | Logitech Quickcam Chat Webcam
I am having touble connecting to the internet with the webcam. We have uninstalled, then reinstalled, and updated all software and yahoo messanger. We have the Logitech Quickcam communicate stx. Please...
Did u try checking the USB cord?Sumtimes faulty cords can coz problems.Try videoing normally thru ur webcam without the internet.Most webcams come equipped wit a software that allows u to film or tek photos using ur webcam.U can use that software or (if u have windows) u cud go to start>accessories>camera&scanning wizard.
And if that doesnt work try to check the settings in yahoo massenger.Go to messenger>privacy settings>click the related tabs and good luck.
And if that doesnt work,,,,,,,,try windows live messenger....
Open a chat window and go to tools>audio and video setup(or something like that) and follow the instructions.
Thats all i gt..........Hope it works 4 u.
If evrything fails,u shud get a new and more simple webcam.....XD or try getting help from the proffesional people,
Dec 25, 2008 | Logitech QuickCam Communicate STX Personal...
How can I get web cam to produce video on a conference call of 3
Video not available on a call with more than 2. Hopefully down the road that can be addressed by Logitech. In the meantime, we will enjoy our visits via conference call and the video one on one.
Nov 16, 2008 | Logitech Quickcam Chat Webcam
GE EasyCam Web Camera
Video or webcam chatting isn't currently supported in Google can yahoo messanger if you want to use webcam or video chatting.............
Sep 19, 2008 | GE EasyCam Webcam
Cam images
hi it is not possible to send or recieve images using webcam,only you can video chat with your webcam
yahoo messenger definitely allows webcam chat .
the user with whom you are chatting must have webcam if you wanna see that person on your screen........!
Nov 21, 2007 | Logitech QuickCam Messenger Web Camera
Cam to dark
try to put on light on your webcam surrounding and then see. bye
Sep 16, 2007 | Ezonics EZCam Webcam
Logitech QuickCam Express Web Camera Logo
50 people viewed this question
Top Logitech Webcams Experts
WTF Chuck.....
WTF Chuck.....
Pieter Vleeshouwers
Are you a Logitech Webcam Expert? Answer questions, earn points and help others
