Question about Poulan Pro PP133 17" Gas Trimmer
Head want turn on pro pp133 - Poulan Pro PP133 17" Gas Trimmer
Will not start, no spark
try this test. take off the spark plug cap ( they unscrew ) snip a small piece off the ht lead ( as the metal inside will be chewed from the thread of the cap ) with a new cut hold the lead against any metal near it ( the cylinder head etc ) and pull it over. you should see a spark from the lead ? if you do you can replace the cap ( it will have new wire to screw into now ) and try fro spark at plug ( no spark new plug needed ) ..if you get no spark from the ht lead unscrew it from the coil and try a new lead
Apr 30, 2015 | Poulan Pro PP133 17" Gas Trimmer
At times the head willnot turn so i turn it upright and tap it on the ground..this seems to reconnect something and it will spin for awhile..is there a set screw or something that holds that shaft?
Check the clutch assembly
Go to the following site where you may find a diagram for yours and also, parts
http://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/poulan/hedge-trimmers/pp2822-966513101-2011-03/engine
Jul 03, 2014 | Poulan Pro PP133 17" Gas Trimmer
Head will not spin when running
Sounds like your drive shaft cable is broken.
Jun 25, 2014 | Poulan Pro PP133 17" Gas Trimmer
Where is the fuel mixture screw on poulan pp133
On the carb. Low for initial and high for top end. Start with both at 2 1/2 turns out. Then adjust low when you pull the trigger to eliminate hesitation. Then floor it and hold while you adjust the high
Feb 16, 2013 | Poulan 25cc 2-Cycle Gas Powered String...
I own a Paulan Pro PP133, 33cc gas trimmer. The trimmer is 3 months old. The trimmer starts, idles, but when I give it throttle to exhilarate or put under load it stalls. It will restart but continues to...
If you bought it new, then you may have water in the fuel, or fuel tank if you left it n the rain. If this is not a possibility, then check out the Link to my Tip:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
The only thing you should have to do in the Tip is step 3.& 4. if your machine is brand new.
Jim
Aug 16, 2011 | Poulan Garden
I have a Poulan Pro PP133 33cc 2 stroke weed eater. It starts but when you give it full throttle it dies. It will Idol but will not accelerate to full power, then it dies if you don't let off the trigger....
check spark arrester in muffller where exhaust comes out there is a screen either under a plate with 3 screws or a round tube that u can pull out with pliers somtimes they clogg with carbon and wont let exhaust out. enuogh at idle but backs up after that hope this helps
Aug 12, 2010 | Garden
Polan pro pp133
Are you saying that this is a brand new trimmer or is it new to you, used trimmer? You are describing a problem that is typical of a used trimmer.
This is a sign of a clogged gas cap. When the gas cap can't breathe, it chokes out the carburetor.
Try this: The next time you run the trimmer, and it starts to die, loosen the gas cap, it should start running again.
Jim
Jun 22, 2009 | Poulan Garden
How do you change a head on a poulan pro trimmer
Just below the gearbox there is a slot and when you turn the shaft there is a slot on the shaft that lines up with that one. Stick a screwdriver in the slot when they are lined up and then grab the head and turn it clockwise. (the threads are reversed)
Apr 22, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Poulan Pro PP133 17" Gas Trimmer Logo
20 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
