Question about Konica Minolta Bizhub 362 Copier
Bizhub 362 will not scan to PDF more than 32 pages
When we try to scan a document to email pdf, it stops at 32 pages. Help!
  • Konica Minolta Master
  • 6,674 Answers
Mite need more memory installed
Posted on Dec 30, 2015
boyrevel
  • 71 Answers
SOURCE: Cannot scan documents on Konica C250/C250P
Go to internet explorer, type in the IP address of the copier, and you will open a page showing you the copier.
Click on the SCAN tab and check the settings.
The most common fault is when the user name and password of the PC has been changed.
Posted on Feb 04, 2008
  • 6 Answers
SOURCE: Konica Minolta 250 Bizhub scanning Operations
what u need to scan to emails is the email smtp ip address.
just put the ip smtp address in the network setting>smtp address
and try to ping from ur B250, if the result is OK, then u have the connection. go to Utility/Counter>user setting>one touch to register
the user address, then scan it, u should be getting the scanned file in ur inbox.
Posted on Aug 09, 2008
SOURCE: Very slow PDF and large files printing
Change to print as an image.
Go to print then click on advance and select image.
Posted on Dec 22, 2008
  • 15 Answers
SOURCE: Bizhub 250 Scan to searchable pdf
This copier scans as an image. The contents of this file are not searchable. The output type (as default) can be set by logging into the web interface of the machine. As for one- touches that are allready setup as tif, you would need to edit the one touch parameters to set the device to PDF. (image only)
Posted on Jun 09, 2009
  • 566 Answers
SOURCE: How do you scan to PDF on a Konica Minolta Bizhub
Touch [Fax/Scan] to display the initial screen for fax/scan operations.
Touch [Scan Settings] to specify detailed settings for scanning
In Scan Settings >File Type , select elect the file type for saving the scan data. The following file types are available (PDF,Compact PDF, TIFF, JPEG, XPS, Compact XPS).
Touch [PDF] or [Compact PDF]
In addition, the grouping of the saved data (single PDF or multi-page PDF) and the encryption settings (encryption level, password, document permissions, and other detail settings) can be specified.
You should check the user’s manual for images and more detailed info on how to operate the machine.
You can download it from here:
http://download6.konicaminolta.eu/konmin/servlet/KonMinMaster;jsessionid=9D04D81DD26189D21B3B2B8B32D2B06F.node02?path=../search.jsp&mode=show&document=32545
Posted on Jul 22, 2009
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
Konica Minolta Bizhub 362: Any suggestions to the problem below? A very frustrating and error-prone device (in printer functionality). It's installed in a 20-user network who do use it lightly (total...
There is another solution but its more costly.All you have to do is to replace the parameter board of bizhub 362 with the board of 363 along with RAMs.
Mar 30, 2011 | Konica Minolta Bizhub 362 Copier
Konica Minolta bizhub C451
yes in your scan setting select scan type in there you will see compact pdf.That will make a 10 meg file be 900k even if it is color.
1twig
May 19, 2010 | Konica Minolta bizhub C450P Laser Printer
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
I cannot scan a document to a single email
file type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
Sep 18, 2009 | Konica Minolta bizhub C250 All-In-One...
How do you scan to PDF on a Konica Minolta Bizhub 353?
Jul 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I want to Scan and send by email in PDF format all pages !!
Looking at my manual , it tells me you have a software user guide on the cd-rom ....this is where you will find the answer.
Jun 02, 2009 | Brother MFC 7840W Printer
Scanning large documents to PDF takes a long time
Try to use Compact PDF or a lower resolution.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 14, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 Scanned files
Try using the Comapct PDF option as a file type.
This should be used if file size is a concern.
It applies a mathematical compression so will affect the quality of the scans very little.
Jul 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub 362 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
