Question about Black & Decker Leaf Hog Blower Bv4000
When I assemble this for the blower operation, it doesn't run
Its possible the switch wasn't in the full off position when I tried to assemble this configuration. Is it that fragile, that it would render it inoperable?
A/c blower motor works if I pull power and plug back in until I cut engine off. Then I have to repeat process
Daryl, You may want to check the blower relay/ just switch with one of same type and try and if OK, problem could be the blower motor, wires/plug loose,damaged,burnt or a faulty blower motor resistor. Second link has some trouble shooting of a overheating wire problem, that is to be common in these trucks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY 2003 Silverado Blower Motor Resistor
Sparkys Answers Chevrolet Silverado Blower Does Not Work On Any Speed
03 Silverado heater fan problem ChevyTalk FREE Restoration and Repair Help...
Jul 19, 2016 | 2003 Chevrolet Silverado 1500
Blower motor 2009 saturn vue doesn't come on, fuse is good, what next?
DISCONNECT THE BLOWER MOTOR POWER LEAD. RUN A "FUSED" (20AMP) HOT JUMPER WIRE TO POSITIVE SIDE OF CONNECTOR,THEN TO BATTERY POSITIVE, THEN RUN A NEG. WIRE BACK TO NEG. AT BATTERY (TO INSURE A FULL CIRCUIT).
IF BLOWER WORKS...YOU HAVE A SWITCH,WIRING, OR FUSE/CIRCUIT BREAKER PROBLEM.NEXT CHECK FOR POWER INTO BUT NOT OUT OF SWITCH...IF THIS IS THE CASE THE SWITCH IS THE PROBLEM.
Mar 03, 2013 | 2009 Saturn VUE
My heat stopped blowing in my 1998 escort zx2 it just quit where do I start I checked all the fuses they are good is there a blower motor relay ??
"I checked all the fuses.." There is only one fuse, the 20A WIPER one in the instrument panel fuse panel which energizes the blower motor relay. The panel also contains the BLOWER circuit breaker which supplies power to the relay. If these parts check OK, there will be 12 volts on terminal 87 of the relay with the engine running and 12 volts on the BLU wire connected to the blower motor. If you set the function selector switch to any position other than OFF, the blower motor should operate at a speed you select by rotating the blower switch. If this doesn't happen, rotate the blower switch to HIGH. If still nothing, the thermal limiter in the blower motor resistor may be open. If still nothing, the function selector switch, the blower switch, the resistor or even the blower motor itself could be defective
Oct 13, 2012 | Cars & Trucks
Blower stays on after key is removed, now a/c works in front once I hit the highway.
Which of these systems does your vehicle have ?
HVAC Systems - Automatic
Blower Motor Control Processor
The blower motor control processor controls the speed of the blower motor by increasing or decreasing the voltage drop on the ground side of the blower motor. The HVAC control module provides a voltage signal to the blower motor control processor over the blower motor speed control circuit. As the requested blower speed increases, the HVAC control module increases the amount of time that the speed signal is modulated to ground. As the requested blower speed decreases, the HVAC control module decreases the amount of time that the signal is modulated to ground.
HVAC Systems - Manual
Air Speed - Front Control
The blower motor forces outside air into the vehicle's interior. The vehicle operator determines the blower motor's speed when the driver places the blower switch in one of 5 blower speeds. The blower motor will always operate in any switch position other than OFF, as long as the ignition switch is in the RUN position. The blower motor and mode switches are located within the HVAC control module. The blower motor OFF input is connected in series with the HVAC control module by the off blower motor control circuit.
Depending upon the selected speed, power is provided to the blower motor from either the ignition 3 voltage or battery positive voltage circuits from the fuse block. The battery positive voltage circuit only provides power when the High blower switch position is selected. Power and ground are provided to the HVAC control module by the ignition 3 voltage and the ground circuits.
Low Blower Speed
When the Low 1 blower speed is selected, the HVAC control module applies voltage to the blower motor resistor assembly through the low blower motor control circuit. Voltage is divided between 4 series resistors, a blower relay, and the blower motor to achieve the desired blower speed. The blower motor is grounded through the ground circuit.
Medium Blower Speeds
When the Medium 1 blower speed is selected, the HVAC control module applies voltage to the blower motor resistor assembly through the medium 1 blower motor control circuit. Voltage is divided between 3 series resistors, a blower relay, and the blower motor to achieve the desired blower speed. The blower motor is grounded through the ground circuit.
When the Medium 2 blower speed is selected, the HVAC control module applies voltage to the blower motor resistor assembly through the medium 2 blower motor control circuit. Voltage is divided between 2 series resistors, a blower relay, and the blower motor to achieve the desired blower speed. The blower motor is grounded through the ground circuit.
When the Medium 3 blower speed is selected, the HVAC control module applies voltage to the blower motor resistor assembly through the medium 3 blower motor control circuit. Voltage is divided between a series resistor, a blower relay, and the blower motor to achieve the desired blower speed. The blower motor is grounded through the ground circuit.
High Blower Speed
When the High blower speed is selected, the HVAC control module applies voltage to the blower motor resistor assembly through the high blower motor control circuit. The voltage energizes the blower relay, causing the blower motor to be connected directly to the battery positive voltage circuit. The blower motor and blower motor relay are grounded through the ground circuit.
HVAC Control Module
The HVAC control module is a class 2 device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive voltage circuit provides power that the control module uses for keep alive memory (KAM). If the battery positive voltage circuit loses power, all HVAC DTCs and settings will be erased from KAM. The body control module (BCM), which is the vehicle mode master, provides a device on signal. The control module supports the following features:
Feb 09, 2018 | 2005 Chevrolet Tahoe
Recirclation light blinks on and off and will not stay on anf fan does not blow at full force when it's switch to level 5.
{: ) Regardless of the blower motor switch position, recirculation is available only in the panel and bi-level mode switch positions. Including the OFF position. The mode switch must be placed in either the panel or bi-level position before the blower motor switch is placed in the OFF position. In order to reduce windshield fogging, outside air is circulated when the mode switch is in the defrost or defog positions. If the recirculation switch is pressed into the ON position when the mode switch is in an unavailable mode position, then the recirculation switch LED will flash 3 times. If the HVAC control module detects a fault with the recirc door the HVAC control module will try to drive the actuator for a predetermined amount of time, to outside air, which is the defaulted position for the recirculation actuator.
As for your blower not full force at level 5, check first the BLWR fuse 40A at the underhood fuse block. If its okay, most likely you have a malfunctioning blower motor resistor assembly.
Jul 06, 2010 | 2006 Chevrolet Trailblazer
Blend door for front temp control is stuck in the 'cold' position this winter. Is there a way to manually move and fix the door to get some heat?
you have to replace the blend (heat/cold) door motor, you can try to remove motor and turn door and try to jam something in door handle slot ,that the part that the motor turns,hope this helps.
Dec 26, 2009 | 2001 Ford Windstar
Heater/AC control switch only operates in high speed. Allother positions don't run.
Sounds like resistor gone, which is in circuit between your controls and the blower motor. Usually located under dash near ducting, or near blower motor, which I believe in your vehicle is located under hood on passenger side firewall area. I normally will follow harness (wiring) from blower and work back to switch at dash to locate resistor. When you check at autoparts store or dealer for new blower resistor, they should be able to tell you probable location if not exact, as well as whether it may be possibly built in to blower motor assembly.
Dec 22, 2009 | 2002 GMC Envoy
No heat
No Blower in Floor Mode
A customer arrives with a 1983 to 1995 Full Size Ford, Lincoln, or Mercury
automobile with automatic temperature control. If the complaint is no blower operation when
the floor mode is selected, the vehicle may have a problem with the thermal blower lockout
switch also referred to as the CELO (cold engine lock out switch).
The thermal blower lock out switch is located in the heater core intake hose. The two
wire switch has a thermal element with a small set of contacts, the contacts are open when the
coolant is below 120°F and closed when the coolant is above 120°F. The thermal blower lock
out switch also contains a vacuum switch, which applies vacuum to the outside/recirculate
valve when the system is in the floor position. When the engine coolant is below 120 degrees
and the selector is set to floor position, the thermal blower lock out prevents blower from
turning on and closes off the outside air during engine warm-up. When the coolant
temperature is above 120 degrees, and the selector is set to the floor position, the thermal
blower lock out switch allows the blower to operate and opens the outside air door.
In order to diagnose this problem, test the thermal blower lockout switch with the
engine at normal operating temperature (above 120°F). Unplug the wire harness connector
from the thermal blower lockout switch. Using a 15-amp fused wire, jumper the harness
terminals to test the switch. If the blower comes on, the thermal blower lock out switch is
faulty. If the blower doesn’t come on, look for an open between the control head selector and
thermal blower lock out switch.
In some cases the blower may continually run even when the engine temperature is
below 120 degrees. Unplug the thermal blower lock out switch and if the blower motor turns
off, the thermal blower lock out switch is faulty. If the motor continues to run, look for a
short to power between the control head selector and thermal blower lock out switch
Nov 04, 2008 | 1988 Lincoln Town Car
A/C FAN NOT WORKING
I presume you are talking about the blower motor and not the cooling fan on the engine?
If you have checked the fuse then ensure there is power at the blower motor when switched on.
Jul 22, 2008 | 2005 Jeep Wrangler
Black & Decker Leaf Hog Blower Bv4000 Logo
62 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
