Question about Zebra Stripe S600 Thermal Label Printer
Zebra S600 LABELS DON'T PRINT IN THE MIDDLE - Zebra Stripe S600 Thermal Label Printer
itdude4321
  • 13 Answers
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Posted on Feb 02, 2008
Joed911
  • 4338 Answers
SOURCE: Need Zebra Stripe S600 Printer Driver
Find the driver at this site:
http://www.howtodrivers.com/model17586.html
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 15, 2008
  • 10 Answers
SOURCE: Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Posted on Feb 17, 2009
  • 32 Answers
SOURCE: Zebra S4M label printer
Check the drive belt. It might be missing a tooth if the printer is older. I can assist if you want to check this.
Posted on Oct 27, 2009
  • 185 Answers
SOURCE: can t print labels they are not align zebra 2844
Press and hold the feed switch and when you see 4 flashes, release the button. The printer will calibrate and you should be able to see the labels align
Posted on Dec 20, 2009
Can a Zebra S600 printer print labels without using a ribbon?
Yes it can but you have to use DIRECT THERMAL MATERIAL. That eliminates the need for a ribbon but what most people don't realize is that a ribbon is almost like "Oil" in your car. Direct Thermal material is more abrasive and will wear out your printhead much faster. Now if you don't print lots of labels that may not be a big deal but if you print 500+ labels a day then thermal transfer may be a better choice in the long run. Printheads are one of the most expensive components of these printers.
Regards,
mikeo@acebarcode.com
Feb 24, 2011 | Zebra Stripe S600 Thermal Label Printer
What is the maximum number of labels that a zebra S600 can print in one Job
Best I could find in the manual was a maximum print length of 38 inches. It doesn't stipulate how many per job.
Mar 08, 2010 | Zebra Stripe S600 Thermal Label Printer
I am having problems with our Zebra Stripe S600 if I ask it to print 500 labels it will only print 3 then I have to line the label and ribbon back up, any advise would be gratefull
Recalibrate the printer, it seems it might have lost it's calibration. Chekc and clean all sensors in the paperpath with Isopropyl Alcohol.
Jan 21, 2010 | Zebra Stripe S600 Thermal Label Printer
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
HOW TO REPLACE LABELS
Look at this I think it will help.
Jan 28, 2009 | Zebra Stripe S600 Thermal Label Printer
Cant seem to figure out how to load the paper in the zebra s600 wont print a full label
Try this. You may not have the labels entering the sensor body & or may not have calibrated the uni25003a9.jpgt. look at this below.
Jan 20, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Jul 30, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
