Question about Zebra Stripe S600 Thermal Label Printer
LABELS DONT PRINT IN THE MIDDLE - Zebra Stripe S600 Thermal Label Printer
Zebra LP2844 pulls labels in before printing
Yes, first of all, it is necessary that the labels are pulled backward (other wise you could not print on the upper part of the label). It appears from time to time that it is a problem - generated by the label itself. Try to use a different label (of size and material) to see if the behavior changes ...
Good luck.
Apr 16, 2013 | Zebra LP 2844 Thermal Label Printer
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
Not printing all labels
Do a calibration, this should fix the issue. Also make sure that the label stopper (silver peg on label holder) is pressed firmly against the labels. This will stop the labels from sliding around during a print, throwing off the calibration. Also check to make sure the sensors are free of any dust.
Jun 17, 2010 | Zebra 105Se Thermal Printer
New LX300+ printers prints middle only
Check your paper size and orientation settings in the printer dialog box.
May 20, 2009 | Epson LX-300 Matrix Printer
ZEBRA PRINTER
Try reloading the TL LATCHFORD software
Thank You
Mar 10, 2008 | Office Equipment & Supplies
Address cuts off when printing large address labels
have you tried restoring your printer properties back to it's default settings? or you can also adjust your margin settings which sounds like the issue but let me know if this helps.. thanks, d
Feb 27, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Label Printing
Forward length matters in Label size detection. Width is just secondary. Length should be same for both. Else no, you have to had separate roll for each label size.
If the labels are same in length then there might be achance using Label Software that supports your printer.
Jan 24, 2008 | Zebra Z4Mplus Label Printer
Labels Print Once Then Fail (3.5 X 1)
"The printer will print one label then either push out a half a blank label or several blank labels. At that point the labewriter thinks it's out of paper. I also noticed that the labels tend to slide toward the middle while exiting. After each print I have to pull the labels back in and realign them. Then the process repeats."
This is because you haven't squeezed both sides of the spool to the edges of the label. Without the sides to hold the label in place it is free to slide about on the spool and therefore slides about where the print head and label sensor are. The sensor is on the left, so if it slides towards the middle the sensor can't see the label and reports "out of labels".
See the diagram here for a clear picture of how to correctly load the labels to avoid this problem:
How to load Dymo LabelWriter Labels
Nov 06, 2007 | Dymo LabelWriter 400 Thermal Printer
Out of order printing..
You did not adjust the label sensor.(media sensor)
1- for labels with a noth move towards the notch
2-for labels with a space between them move towards middle.
look at page 28 (zoom 400%)
http://www.posguys.com/download/DataMax-I-ClassManual.pdf
Oct 16, 2007 | Toshiba TEC B-SX4 Thermal Label Printer
Envelopes and labeles
Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
Oct 15, 2007 | Samsung ML1740 Laser Printer
Zebra Stripe S600 Thermal Label Printer Logo
21 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
