Question about Olympus DS-2300 Digital Voice Recorder
Need driver Need a driver to support above on window 7 with 32 bit computer
How do I make my epson stylus NX330 printer recognize my computer so I can scan to it.
  • http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=183403&prodoid=63091347&infoType=Downloads&detected=yes&platform=OSF_W_7-64
    Drivers and Utilities Combo Package 11/17/11 90.5 MB DownloadDescription: This file contains everything you need to use your Epson Stylus NX330 wirelessly or wired.
    This combo package consists of the following items:
    • Printer Driver v6.91
    • Scanner Driver and EPSON Scan Utility v3.781
    • Event Manager v2.50.00
    • Network Installer
    Compatible Systems: Windows 7 32-bit, Windows 7 64-bit, Windows Vista 32-bit, Windows Vista 64-bit, Windows XP 32-bit, Windows XP 64-bit
Not what you are looking for?
View all downloads for Windows 7 64-bit in the sections below, or select a different operating system above to reveal other downloads for your product
Nov 09, 2012 | Epson Stylus NX330 All-In-One Printer
Is there an updated Acer ScanPrisa 124Out driver compatible with Windows 7 anywhere?
Unfortunately, there are no Win7 drivers for this scanner. THe drivers are for Windows 98SE through XP. The support for the ScanPrisa 1240UT is available here: http://benq.co.uk/support/downloads/downloads.cfm/dtype/M/page/downloads/product/87 . Click on the Drivers tab.
The XP driver may work under Windows 7 32-bit in the Compatibility Mode. (To check your version of Windows 7, click Start > Control Panel > System and Security > System. If the Windows version title ends with x64, you do not have the 32-bit version. Otherwise, you do.) To use this driver in Windows 7 32-bit, download the .zip file and extract it. (Right click and choose Extract All.) Then find the installer (Setup.exe) and right click again and select Properties. Click on the Compatibility Tab and check "Always run this program as compatible with" and fill in XP in the drop down menu. Right click again and choose Run As Administrator.
If you have Windows 7 64-bit, you will need to use a computer with the older version of Windows. This can be a virtual computer (if your hardware supports it), a dual boot machine, or a physical second computer. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP computer for free (again if your hardware is capable of doing it). In that case, download Virtual PC and XP mode from Microsoft. Install the programs in order. Then install the scanner using the drivers from the above link as if the XP mode is your regular computer. Other virtual computer programs include VMWare and Parallels. However for those and the other options, you will need a licensed copy of the older versions of Windows. (If you know a Windows User's Group member, you may have a source for older versions of Windows.)
I hope this helps.
Oct 14, 2011 | Acer ScanPrisa 640P Flatbed Scanner
Do you have drivers for canon printer mp198, my driver is missing i need to download drivers
Since you didn't mention the Operating System installed on your computer, I am unable to make this very specific. Follow the below links.
1. Windows 2000/Xp/Vista/7 32 bit driver for Canon Mp198
2. Windows Vista/7 64 bit driver for Canon Mp198
Open either of the above links and scroll down the page, select "I have read and understood the above information and wish to download the designated software" and then click "Download" button. If you don't check the above option i.e. "I have read......" you'll never be able to click the "Download" button to begin the download.
If you need further help or if you have problem, let me know.
Good Luck.
Thanks for using FixYa.
Mar 07, 2011 | Office Equipment & Supplies
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
When trying to add my printer(LEXMARK 6150) to my computer what model/make do I select to make my printer compatiable with my computer?
You should select your make and model. If you do not have a printer driver showing up in your options to select you need to download a printer driver from here.
The Windows Vista driver will also work for Windows 7. Select the version of your Windows operating system, i.e Windows Vista (32-bit) or Windows Vista (64-bit).
If you do not know the version of your operating system, open Control Panel, click on System and look for System type.
Download the available driver and note the location where you save it. Use the add a printer function and if necessary point to the driver file location if the install program can not find it.
Shoud you need instructions with greater detail look under the Top Articles tabs at the above link for further assistance on how to download and install a driver.
Trust this is helpful.
Jan 01, 2011 | Lexmark X6150 All-In-One InkJet Printer
I need the softw for microscope qx5, i am of Chiapas Mexico thankyou
Here are the links to the available downloads from Digital Blue:
QX5/Smithsonian Computer Microscope Drivers for WIN ME, 2000, XP, Vista 32-Bit
Download Drivers
QX5 V2 Computer Microscope Drivers for Windows Vista 64-Bit
Download for Windows Vista 64-Bit
QX5 V2 Computer Microscope Drivers for Windows 7
Download Windows 7 32-Bit
Download Windows 7 64-Bit
Oct 14, 2010 | Digital Blue QX5 Microscope
I would like to download software to windows 7 laptop
Click here Click on above link then download driver for your os . Let me know if you need further assistance. Thanks for using FixYa.
Sep 17, 2010 | Lexmark X3480 All-In-One Printer
I need the software for the QX5. Is there a spot to download this info?
Download Drivers
QX3, QX5 V1, QX5 V2 Computer Microscope for Mac OSX 10.4-10.6
Visit Webpage for Download
Aug 20, 2010 | Digital Blue QX5 Microscope
Lost Install CD For Quickcam Communicate Plus (S5500)
I'm pretty sure the drivers will work the same.
To find out if you need 32-bit or 64-bit, just do the following:
  • Click on Windows Button
  • Right-Click on Computer
  • Click Properties
  • Scroll down to System Type and you will see if your machine is 64-bit or 32-bit.
Regards
Jan 12, 2009 | Logitech QuickCam Communicate STX Personal...
Olympus DS-2300 Digital Voice Recorder Logo
27 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
