Question about 1A Auto Parts 1995-1999 Olds Delta 88 Intake Manifold Upper V6 3.8L excluding Su
How often should the oil be changed in a 1995 olds 88
How often should the oil be changed in a 1995 olds 88 , mileage 97 000
I have a 95 toyota 4 runner sr5 v6. It is not getting good gas mileage. I have changed the air filter and the spark plugs and nothing has changed.
After a good tune-up may other factors affect your gas mileage, tire pressure, acceleration, traffic conditions, driving habits, etc. The only thing you can do is make sure its well tuned, has regular oil changes, clean filers and drive like a 90 year old lady! Outside of that, think about getting a newer more fuel efficient car.
Mar 21, 2015 | 1995 Toyota 4Runner
1995 Oldsmobile 88 LSS 3.8 smokes at idle
Valve stem seals. Oil is thicker when cold (hence no smoke when cold) Vlave stem symptoms are when engine at idle (high vacume) oil is pulled through the guide seals, when you take off from lights get bit of smoke until oil is burnt. Ring symtoms is it would be blowing smoke all the time especially at higher rpm for extended time ie: driveing. Have you thought of trying a thicker oil? what oil grade do you currently run?
Jun 28, 2012 | 1995 Oldsmobile 88
1995 Olds. 88 instrument cluster swap
You need the sensors of those functions, which you don't have installed. I would go back to the correct part.
Jun 22, 2012 | Oldsmobile Eighty Cars & Trucks
I'm proudly own a 1995 Toyota 4Runner with 3.0L V6 engine, with 149k on it and i want to ask if there's any way to improve MPG, i put correct pressure on tires, clean MAF sensor, altough no...
verify good spark plugs and correct ignition timing. make sure the engine is getting to correct temp (195f) Has the mileage always been this bad? be sure the cam timing is correct.
Aug 30, 2011 | 1995 Toyota 4Runner
I have a 1995 olds aurora with a northstar. The oil level is fine but the computer says low oil pressure when at a stop light. Is this the oil sensor or oil pump?
Oil pressure is generally not related to oil level unless the oil level is low.
Oil pressure is created by a pump and as the engine parts wear over time, the oil passes through them easier causing oil pressure to drop.
It is also possible that the loss of pressure is caused by an oil pump that has worn, but don't get your hopes up.
If the vehicle has a lot of mileage, has been driven hard, has not had the oil changed regularly, this occurs.
It is sometimes possible to put additives in your car that are "thicker" than oil and this will give you some time to decide what to do.
Gary
Jul 21, 2011 | 1995 Oldsmobile Aurora
Fuel smell in quickly darkening engine oil
use a normal oil cheapest you can get and change it every 6000 miles with the oil filter every third oil change .as for oil getting dirty thats what its meant to do ,and the smell is that synthetic oil and it additives
Jan 09, 2010 | 1999 Oldsmobile Eighty Eight
95 olds 88 3.8 engine died, won't start plugs are wet with gas coil packs and wires are firing. Engine tries to start
sounds like its flooded, check oil level, if its high replace it, disconnect fuel system , clean and dry plugs, then turn it over ,
Nov 27, 2009 | 1995 Oldsmobile 88
What is good oil to use when doing a self oil change on a 1995 Camry
if you have a car with high mileage,, use a oil for that(castrol high mileage oil) for an example
Aug 12, 2009 | 1995 Toyota Camry
How do I remove oil pump pulley to replace the water pump?
If you mean the power steering pump, it will have to be removed to access the bolt. It's just 2 bolts. You get them through the holes in the power steering pump. Just unbolt it and push it aside.
Feb 14, 2009 | 1995 Oldsmobile 88
2002 525I Just after recent oil change I was sitting at a stop light, Light changed I gave the car gas and a big puff of white/blue smoke came out. It has done this ever since. The car has has 97,000 mi,...
Have you used the correct grade of oil for the engines mileage? If you add a can of Wynns Smoke Stop that will thicken it a bit and help to stop/reduce the emissions.
Mar 26, 2017 | 2003 BMW 3 Series
1A Auto Parts 1995-1999 Olds Delta 88 Intake Manifold Upper V6 3.8L excluding Su Logo
500 people viewed this question
Top 1A Auto Parts Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a 1A Auto Parts Kitchen Appliances - Other Expert? Answer questions, earn points and help others
