Question about Kitchen Ranges
Lg electric range problems
Lre6321 all burners and oven will not work, but all of the 110volt stuff works(display ect.).any ideas?
fridgetech
  • 473 Answers
SOURCE: clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Posted on Oct 05, 2007
the dr
  • 447 Answers
Let me know the model# and ill see if there are any thermal fuses. If not than most likely you will have to replace the EOC (Electronic oven control). Available at www3.sears.com
aborcass
  • 2651 Answers
SOURCE: whirlpool gold electric range control panel blinks w/all lights powers oven off
you say after 5 min of plugging in , is this brand new and still covered under your 1st year warr???if so get an authorized servicer out there to take a look at why should you be responsible for their problem
Posted on Mar 17, 2008
SOURCE: Electric range burners and oven
check the power behind the stove, the outlet for 220 volts, i just fix one with the same problem, it was getting 110 volts but not the 220 volts. so there was nothing wrong with the stove but with the power source.when the stove indicator lights work and the clock, it means that only 110 volts are coming to the stove.
Posted on Dec 10, 2008
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
My oven does not heat up. Everything else on the stove works (top burners, clock, timer, ect.) When you turn the oven dial, it even clicks as if it were to start the oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 10, 2011 | GE JGRP17 Gas Single Oven
Magic Chief "Chateau" double oven,
I just had the top completely off of our Magic Chief, which I love and refuse to part with, to fix a problem with one of the burner switches. I believe if you pry up gently in the crack in front with a blade, i.e. small pry bar or screwdriver, being very careful to not chip the paint, the top will snap loose from the two prongs that hold it in place. Then if you disconnect the cluster of wires going to the burners, which is very easy to do, (they just plug together) and remove one screw holding the ground wire toward the back, you can lift off the whole top and get to all of the good stuff. I find the quality of our old Magic Chief Chateau to be of exceptional quality, much better than I see today and I'm pleased that our burner problem was just loose screws. Good luck.
Jan 02, 2011 | Magic Chef Kitchen Ranges
The display and all oven functions are not working
with out a display it hard to set oven tempt ect . you will have to replace the e r c ( clock ) to correct problem .. mm
Jul 14, 2010 | Whirlpool Ovens
I have a GE Profile free standing gas range JGB920sefss, the display for the clock & oven temp etc doesn't work so we can't use the oven, but the burners and interior oven light work any ideas???
Sorry, usually that is a bad control board. It looks like they are available at www.appliancepartspros.com for $121.50 You'll have to decide if it is worth fixing.
Apr 26, 2010 | Kitchen Ranges
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Lights & oven don't work, burners do
If this is a 220volt unit make sure to reset both breakers in your electrical box. If it is a 110volt unit you may try reseting the board by unplugging it for ten minutes then plug it back in. Hope this works. There aren't any available repairs to the control center which would mean a new one! Thank You, Dana
Aug 22, 2009 | GE Kitchen Ranges
Top burner is stuck on and F1 showed on the display
Hi Krista,
Unfortunately, F1 is a fault code for a failed electronic control... it'll have to be replaced. The reason the burner is on is that the relay controlling it has welded closed allowing power to the burner full time.
If you choose to repair this yourself, could you provide the model number? That way, I could pull up schematics and stuff I need to further help you.
SG
Apr 05, 2009 | Kenmore Ovens
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
