Question about Compaq Presario M2000 Notebook
Compaq presario m2000 imediately shuts down after
Compaq presario m2000 laptop imediately shuts down after boot. Worked fine before...
    Scholar:
  • 94 Answers
This is similar to what happened to me, but mine restarted right after boot.
First, are you on a/c power, or battery? If on battery, check the power status.
Second, there might be a problem with your hard drive. Based on your type (SATA, etc) replace it or send it in (if your product is still in warranty).
Hope this helps, and please rate~
Posted on Jun 18, 2009
    Sergeant:
    Champion:
  • 253 Answers
Check for blocked air passages - vacuum out the fan ports. (Don't use canned air - you'll just blow the dust inside, where it will act as an insulator and help things overheat.) Make sure the fans are actually turning. If there's any mold growing inside, that could cause the problem too.And for more contact http://tinyurl.com/m7ghqz
Compaq Presario M2000 stopped turning on
If there is no power going to the laptop then disconnect battery and hold the reset button in for 30 seconds, then try it again. Sometimes the memory can be damaged which can cause the laptop not to boot..?
Feb 08, 2013 | Compaq Presario M2000 Notebook
Do compaq presario m2000 laptops have sata ports
This model Compaq laptop does not have any SATA connections/ports.
This WEB site shows the specs for this laptop.
http://www.ehow.com/list_7325244_compaq-m2000-specs.html
Jan 05, 2013 | Compaq Presario M2000 Notebook
My presario m2000 will turn on but comes up with a screen
This is happening because you're not turning the computer off properly, make sure everytime you turn your computer off you go to
Start menu
Shut down.
You need to select start windows normally.
Safe mode will help you with some otherthings
just make sure of turning the pc off properly ;)
Apr 27, 2010 | Compaq Presario M2000 Notebook
Compaq M2000 boot
check your memory card(s) you may have a bad on or two, and if that doesn't work then sounds like the mother board has become defective and needs replacing, but the ram Memory would be the cheeper fix first.
Jun 22, 2009 | Compaq Presario M2000 Notebook
HDD Upgrade and Specs for Compaq Presario M2000
Yes the M2000 will support at least an 80GB hard drive.
Jun 11, 2009 | Compaq Presario M2000 Notebook
Presario m2000 just shuts down while in use
Usually this problem occurs due to a thermal[overheating] problem. Make sure all vents are free when running the laptop. You can also fix this by upgrading the fan & buying a laptop cooling pad that sits underneath the computer when in use. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | Compaq Presario M2000 Notebook
check the sound card drive
see if u have installed the same driver required by the laptop
Nov 10, 2008 | Compaq Presario M2000 Notebook
Fine horizontal lines on the screen
this may be due to fault in your display panel, check it by some hardware professional nearest to you
Oct 03, 2008 | Compaq Presario M2000 Notebook
Compaq m2000 boot problem
i suggest you go to bios setup and restor the default if it continues try replacing a diff hard drive or dvd drive drive thats not the one u r using rigght now and i think the problem will be resolved cos i had a similar problem with presario c500 what i did was change the dvd drive n it work well.
hope this helps
thank u for using fixya
May 27, 2008 | Compaq Presario M2000 Notebook
Desktop Display
Shut down the computer. Turn it on and during the boot process hit on F8 to get into Advanced boot option (if it skips try again after restart the computer), You will see the options. Choose "Last Known Good Configuration" and enter. It will probably will resolve the issue. If issue persist please post for further assistance.
Good Luck
Feb 03, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
135 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
