Question about Simplex Kaba Ilco Unican L1000 keyless lock
How do i take the door knob off a unican lock
5 Suggested Answers
SOURCE: lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
Posted on Jun 26, 2009
  • 963 Answers
SOURCE: Trying to identify the model
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: How do you remove a unican from an existing door?
I
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
  • 963 Answers
SOURCE: Unican 1000 locked out of
I don't think that you have much of a chance since the lock is doing exactly what it was made to do--preventing bypass and entry from the outside!
That said, I don't have a direct answer, but here is the contact info you need for customer service. They may be able to help you:
1-800-849-8324 (option 1)
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Kaba Ilco is in North Carolina, so it's probably best to call during Eastern Daylight business hours.
Good luck--and please provide feedback if this helps!
Posted on Aug 25, 2011
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Is there anybody to help me? It's urgent please...
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Good Luck!
Mar 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Hi, I have an older version of the Ilco unican corp pistol safe. IT is a simplex with the push buttons and a silver turner. I got it open, but don't know how to re program the code. Any help?
pctuneup191
REMOVE THE KEY.
Good Luck!
Feb 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Could you please help me. Thanks.
I believe you can find this to be relevant:
REMOVE THE KEY.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
Feb 14, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How do I change the code on the Kaba IIco Unican 1011 keyless lock?
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Good Luck!
Dec 21, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
Need to know how to reprogram the code on a Simplex Kaba IIco Unican 1000 keyless lock
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Good Luck!
Dec 05, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Forgot code to Unican L1000 lock. How can you reset code?
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
Oct 29, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
How do you remove a unican from an existing door? I was able to remove inside knob but there are no visible screws to remove the plate.
I
Sep 11, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Want to reprogam keyless lock unican push button lock please advise ------thankk you...
Turn knob once. Put in present combination. Open screw on the top, Use a small rod or drillbit  that will fit into the hole. Press straight down on a lever that is inside of the hole,until it clicks. Turn knob completely(once) to clear old combination. Put new combination in, making sure that a click is heard upon pressing each button.  Try knob with both the old and the new combination. Each digit may be used only one time in the combination.
Dec 31, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  L1000 keyless lock  Logo
76 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
Pamela Leach
Pamela Leach
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
