Question about Toys
GV 100% WW BRD 16 - Toys
Have geovision gv-600, the video lost on 5 out of 10 cameras?
If you confirm this is the card and not the cameras, then you may have some bad ports. You may need a new card. It happened to me at a customer after a lightning strike. Although mine was 4 cameras (1-2-3-4). You can also verify that the cameras are activated on those channels. That would be the easy fix.
Apr 11, 2013 | Geovision GV-600-16 Digital Video Capture...
My geovision multicam program(gv-800) will not respong I have recovered my computer and it still wont respond. Please help!
Having recovered means there was a problem before. try to install the device drivers for the video capture card all over again
Jul 15, 2010 | Geovision GV-800-16 Video Capture
Cant view vedio log on GeoVision GV-600
Okay - try going into the software directory and delete the files maked .db there should be one for each camera. Then start the software and try it again.
May 14, 2009 | Geovision GV-800-16 Video Capture
Do any1 know is it possible to use 2 Geovision Gv 800 in one PC?
yes you can, but recording will depend on size of hard drive. i work in the trade and you will require at least a terra bit to run 32 cams for any given period
May 07, 2009 | Geovision GV-800-16 Video Capture
Can't find USB key.. GV 800 v7.05
Install Version 6.05 that should do it
Jan 12, 2009 | Geovision GV-800-16 Video Capture
Gv-800
This problem could be because of the GV card version not compitable with GV main systems software you install please check the hardware version of the GV card and compare for compatibility. East way out downgrade to lower version of software. for example if you have version 8.1 install then install version 7.0 or something like that.
Aug 27, 2008 | Geovision GV-800-16 Video Capture
Toys Logo
42 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
