Question about Vehicle Parts & Accessories
Front suspension clunk
1999 vet
    Sergeant:
  • 462 Answers
Broken strut or spring
Posted on Sep 07, 2014
My 2001 saturn sl1 front end clunk when driving
You have not described it very well so it could be a number of different items.
If it sounds like a rotational clunk the it will possibly be the CV joints that need replacing.
If it is not a rotational type clunk then it will most likely be a suspension component. It could be as simple as a worn suspension bushing that it allowing metal to metal contact or something much more significant in the front suspension system.
Without physically checking the vehicle it is difficult to be more definitive but needless to say you must have it checked out and the cause identified.
Jan 30, 2016 | Saturn Cars & Trucks
Replaced complete control arm with new ball joint but still clunking.. can it be the wrong bolt or wrong hardness of bolt??
Is the clunking occuring when steering or just on rough roads? With suspension clunks tie rod ends are the most comonly over looked component. To check the tie rod ends jack up each side individually and place jack supports under vehichle in manufacturer allocated position with the parking brake on , on a flat surface . Check the tire deflection by attempting to turn the tire by hand in a side to side fasion also check the lateral deflection of the wheel bearings . There are inner and outer tie rod ends on your vehichle . Other suspension components that can cause clunking are the struts to check these bounce the car as you would a basket ball with your hand by pressing firmly down on each front corner and releasing you may hear the clunk during this test as well.
Oct 14, 2013 | Suspension & Steering for Mazda MAZDA5
1999 olds 88 ,clunk in front suspension
How is the strut mount on top ?
Jul 03, 2013 | Cars & Trucks
Suzuki SX4 2006 A clunk noise coming from the front suspension. Changed the links on both sides and torsion bar bushings. There is still noise coming from the suspension.
try changing the shock absorbers bushes. also sometimes the springs clunk because when someones removed them they've forgot to put the rubber back in between the spring and the body.
Mar 14, 2011 | Suspension & Steering for Suzuki SX4
1999 honda passport. clunks when stopping and a
have the rear chunk and front chunk checked out could have slack in gears.
Aug 28, 2009 | 1999 Honda Passport
My 99 GMC suburban 4&4, has this clunking noise in the front when I go over speed bumps, replaced shocks, but no help, any ideas?
Inspect rubber bushings in the suspension, it is at the age where they will start to wear out. Also inspect the ball joints, these can make a lot of noise when going out.
Jul 27, 2009 | 1999 GMC Suburban
2000 Explorer Clunks, sounds "loose" suspension
it sounds like the radis arm bushing are wore out they are the arms that go between the frt. axle to the frame they have round bushings that are bolted the the frame rails just behind the frt tires.
Mar 04, 2009 | 1999 Ford Explorer
Clunk sound from the left front of my 1999 300M
are they the original struts in the front .if so replace the strots and strut plates .
Mar 03, 2009 | 1999 Chrysler 300M
Knocking on steering / braking
Sway bar links are also part of the suspension that you really can't feel while driving. If you're handy enough take your front wheel off and you'll see a bar passing through to each side of your front suspension. It is connected to the lower control arm by sway bar links. The links have ball joints enclosed by rubber boots with grease. Eventually this grease will come out or the boots will tear and you'll hear metal on metal while force is applied. These are fairly cheap to buy yet you may have some trouble getting them off without air tools. If you try to do it your self i'd suggest spraying the bolts down with some lubrication.
Jul 22, 2008 | 2001 Subaru Outback
Vehicle Parts & Accessories Logo
19 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
