Question about Philips Audio Players & Recorders
I have a CD that will not eject from my car CD player. when eject is selected there is a clicking sound for 10 seconds and then it stops. Is there a method for removing a stubborn CD without major surgery?
  • 6,784 Answers
This will not be easy. the actual loading track motor and track assembly has become stripped and, you will need to disassemble the unit in order to extract the trapped CD in this case.
Unfortunately, there is no escape button on this particular unit.
Posted on Jun 19, 2009
I have 2003 toyota camrey and im having trouble with my cd player/ radio. I pressed the eject button my cd came out and i tried to put another cd in and it wont go in. so then i pressed the eject button...
get a new cd player... u could have already purchsed one instead of logging in to post this... plus aftermarket are better then stock toyota stereos anyway
Feb 23, 2011 | 2003 Toyota Celica
My Sony CDP-C910 cycles through CDs, never playing
when its cycled thru them .,does it stop?does it show them on the screen with a lit circle?are they normal cds.can you select one cd to play?hold the eject button in for about 5 seconds,see if that resets it
Jul 11, 2010 | Sony CDP-C910 10-Disc CD Changer
Selective CD player
you need to use cd-r + look at the ones that don't work they are cd-r- you might of also not closed out the disk that would keep the disk where it would work on you pc but not your cd player.
Aug 23, 2009 | 2007 Chevrolet Malibu SS Sedan New Cars
Have a 6 disc cd player in a BOSE 30 Lifestyle system that will not eject the cd holder
May i suggest you try selecting each of the 6 CD's then depress each of these buttons waiting about 10 seconds between each press - play, stop, eject. You can also try powering off the unit between each press. It may be the microprocessor that send the commands to logic circuitry to perform the next mechanical funtion. It isn't necessarily something that you did wrong. It could simply be an electronic failure.
Jul 04, 2009 | Bose 3·2·1 II System
CD stuck in Factory installed CD player
TRY REMOVING THE RADIO FUSE FOR 30 SECONDS THEN REINSTALL IT. THE CD PLAYER WILL SOMETIMES EJECT THE CD OR EVEN START WORKING PROPERLY AGAIN.
May 18, 2009 | 2006 Pontiac Grand Prix
CD player doesn't work...
most cd players have a reset button underneath the faceplate. try hitting that and see what happens.
Mar 30, 2009 | 2003 Toyota RAV4
Buick Rainier--CD will not eject--will play but will just click
ok i no this is prolly not the answer you want but i have ran across this a thousand time it is very commen with the gm cd players i have yet seen anyone fix this problem best bet is to replace the unit and aftermarket is a good cheap way to go
Mar 27, 2009 | 2005 Buick Rainier
Nakamichi CD player ejects discs
I think either your disk player, or your CD is dirty.
You should probalyly try getting a Q-tip slightly dampened in rubbing alcohol .
and clean the inside of your player.
Or you should try a different disk
Dec 31, 2008 | Audio Players & Recorders
6 disk CD changer is broken!
Hello, I just removed the 6-disc player from my 2001 Trooper. To remove it: 1) Remove the two screws above the radio area in the black faceplate 2) Remove the one screw located between the ash tray and the lighter. 3) Remove the four screws (two on each side) from the front center console cover and pull it back (you will need to shift into 2 or L) 4) Pop the black face plate off (there are some metal brackets holding it on that need some light force to pull out. Nothing should break) 5) There are two screws for the CD player and two screws for the radio. Unscrewing them will allow you to pull out the radio and disconnect the smaller CD wiring harness, then you can pull out the CD player.
When I unscrewed the CD player unit, I found that there are six plastic halos that hold each disc and move them up and down as selected. These had broken in some places and the discs had dropped to the bottom and stacked, so nothing could move...hence the clicking sound. Because there was a severe jam, nothing else could be loaded either...hence the error message. I'm attempting to superglue the pieces back together to see if I can reset it. Otherwise, I'd recommend you replace the unit (most likely what I'll do).
Hope this helps!
Ryan
Nov 08, 2008 | 2000 Isuzu Trooper
2004 camry cd player stopped playing
I have 2004 Camry. CD player did not work right after my 5 year warranty was expired. I heard from my friends that other Camrys have same problems.
It can not read the tracks in CD and ejecte, I told Toyota dealer, they said $250 to replace with new one including labor.
Any help would be appreciated.
Thanks,
Peter
Jun 04, 2008 | Car Audio & Video
115 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
