I instaled a new ink cartridge and came up with a error code #1200 see owners mannuel. The ink cartridges will not move to center when opening doors and cannto get at them to make sure that they are instaled correctly.
Tried what blkghost suggested above but had to tweak his advice slightly.
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
YAY problem fixed.
Copy of x4270 owners manual (Help)
TY TY TY! WORKED!
To see if the cartridge is in the place, try this connect the power cord and when u see the printer become to work moving a little bit turn off the printer on the power cord. Then u can freely move the cartridge, to see if any problem.
I installed both new black and color cartridges and now get "error code 1200 see owner's manual". I have tried what owner's manual offers and nothing works. The cartridges won't come to center of belt when printer cover is opened. Help!!!!!!!!!
I get error code 1200 - cannot find the owners manual. Help?
[email protected]
error code 1200
STOPPED PRINTING, ERROR #1200 OPENED DOORS TO VIEW CARTS,BUT CARTS DO NOT MOVE INTO VIEW,CHECKEDPOWER & CABLE(SEEM OKAY) I THINK I NEED A TECHNICIAN WHO IS FAMILIARWITH THE X4270 CARTRIDGE SETUP THANKS,MFS
Posts error #1200 do not have user manual need help
error code 1200
how do you fix it?
replaced catridges And tried to center them
changed ink cartridge,now onk will not move to center
error 1200 ink is stock
I followed the same with success except that I had to repeat three times.
thanks a billion for your advice
neal alexander
I have done all of these steps repeatedly and still cannot get the error to go away...HELP!! I bought a new ink cartridge just in case, so I am stumped..
Although both cartridges are in place I keep getting the error message that 'print cartridge is missing'. I tried the foll.suggestion
"....Turn off power to the printer and unplug it from the back of the printer.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay..."
Hoever I never receive the message then that the black cartridge is missing after foll. all the above menbtioned steps.
Please help.
Ink cartridges will not move to center opening when trying to fix error code 1200.
