Question about Speck Pumps Pool & Spa
My pump does not start and make a humming noise
    Top Expert:
  • Speck Pumps Master
  • 6,465 Answers
Bad capacitor or motor
Posted on Nov 23, 2017
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
My 2001 chevy malibu had been working fine up until this afternoon it turns but wont start,itmakes ahumming noise even when i turnoff key.
That humming noise may be your fuel pump burning out. Try turning the key to the on position while someone else listens near the gas tank. The humming should only hum for a few seconds so you won't have time to listen yourself unless you can hear it from inside. If the hum continues and doesnt shut off, it is likely a bad fuel pump. It is normal to hear a small hum for a couple of seconds , but when it starts getting weak, it will hum louder, longer, or not at all
May 11, 2015 | 2001 Chevrolet Malibu
Dishwasher is humming when turned on like pump noise but not starting the program
the first thing any dishwasher does is drain, so if its humming instead of the normal noise there will be a piece of glass or something similar stuck in the drain pump it will need to be removed and cleaned out
Oct 09, 2014 | Beko Dishwashers
Fuel Pump
A humming noise in the gas tank is usually a failing fuel pump.
The pump uses liquid gasoline to keep it cool and lubricated.
May 01, 2013 | 2004 Pontiac Grand Prix
Humming noise when i turn the key on in the morning
power steering pump make humming noise and alternator with bad shaft bearing make noise.
Feb 12, 2013 | 2005 Toyota Sequoia SR5
My fuel pump is not starting no gas gets to he motor
Fuel not starting.turn the key on but dont start it do you hear a humming noise (there loud on Ford) yes the fuel pump works No humming noise then the pump is not working. One more thing do you have the owner manual yes okay we need to find the fuel shut off valve more likely it will be in the trunk are open the trunk did you find it it should be to the left and it will say fuel shut off push the button go back and turn the ignition on does the humming noise start?
Apr 22, 2011 | 1999 Ford Taurus
1988 subaru GL 10. It wont start after it has ran a while. The humming noise that I assume is the fuel pump coming on just before I start to crank does not hum on those occassions when it wont start. If...
Most likely a bad fuel pump, try turning the engine over while someone bangs on the fuel pump, located under the car about the right rear passenger seat area, if it starts you have a bad pump & it needs to be replaced.
Jan 15, 2011 | 1988 Subaru GL-10
I have a '96 cavalier that makes a humming noise in the gas tank within 5 seconds of starting. I have tried two fuel pumps but the noise is still there!!!
Your fuel pump is supposed to hum, when you turn the key it primes the system and it will hum. When the car is running the fuel pump is running and it will hum. If the noise is excessive then try a higher quality fuel pump, it may be less noisy. You will hear the fuel pump on a lot of vehicles tho when you are sitting at a stop light with your radio off and everything quiet in the car.
Apr 08, 2010 | 1996 Chevrolet Cavalier
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
Nov 08, 2008 | 1995 Honda Civic
Pool & Spa Logo
59 people viewed this question
Top Speck Pumps Pool & Spa Experts
Gil Shultz
Jay Finke
Jay Finke
ELECTRICKS
ELECTRICKS
Are you a Speck Pumps Pool and Spa Expert? Answer questions, earn points and help others
