Question about SPORTSPOWER LIMITED New Timber Play II With Balcony Swing Set
Sportspower Timber Play II with Balcony
What do I need before I start
Building a pergola 5,5 metres x 2,5 metres what size timber do i need for 5,5 metre span
different grades of timber and types of timber have different strengths
a laminated beam will be stronger than a solid beam and will be less in dimension to do the job
Architects have a book showing timber strengths for lengths so find an architect and get the right advice from him
if you find that the beam will be too big for what you want, consider using a steel rhs beam and using timber as a surface finish on 3 sides
that is a common practice in building structures
Feb 18, 2017 | Office Equipment & Supplies
Timber tuff 5 ton eletric log splitter will not move
check/replace the start/run capacitor/s
check that the hydraulic pump is not seized
Oct 26, 2015 | Timber Tuff 5-Ton Electric Log Splitter
Need instruction/assembly manual for this product
My wife finally found a number that will email you a PDF file that has the assembly instructions. Here it is. The name of the company is Sports Power 866-884-0535.
Oct 23, 2013 | Sportspower Vertex 2 Piece Table Tennis...
Tent replacement parts
Tent-Parts.stuccu.com. This is only one place you can get replacement parts for tents online. This one should be a good starting point.
Oct 03, 2013 | Timber Creek Camping, Backpacking & Hiking
Need to replace a 2' x 6" section of my balcony
replace the whole board, there is also a product woodlike filler that works even in the rain. will set up harder than original wood, ask at home depo, you want to stop rotting as it quicly spreads
Jun 24, 2013 | Cars & Trucks
I'm going to buy Assasin's Creed II or AC Brotherhood. Can I start with Brotherhood or need I play AC 2 first?
You can start with either one. I really enjoyed AC II and am looking at buying AC III very soon.
Dec 06, 2012 | Video Game Consoles & Games
Washing machine rocks very hard during the spin
If the machine is not on a very stable surface...such as concrete....this can happen particularly if the machine is now on a timber floor. The floor literally vibrates in sympathy with the machine.
If however this is the same machine now showing this on the same surface then either something has come adrift inside or the stabilising in it has failed in some way or it has a bent main shaft in which case you will need a Techo service call.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
SPORTSPOWER LIMITED New Timber Play II With Balcony Swing Set Logo
Top SPORTSPOWER LIMITED Toys Experts
Andrew Taylor
Andrew Taylor
Are you a SPORTSPOWER LIMITED Toy Expert? Answer questions, earn points and help others
