Question about Lexmark Wheelwriter 15 Series II Typewriter
IBM Selectric II - Element Ball
When I put the Element ball on the arrow doesn't face toward the platen and then the letters I type are wrong. I have tried to move the stem the ball goes on, but it won't budge. Help
  • judyhansen Jun 19, 2009
    Thanks so much - I think that is exactly what is wrong with it.
  • Lexmark Master
  • 3,594 Answers
The rotate tapemay be broken or come off one or the pullys.
Tou should take it to a tech.
DickyO
Posted on Jun 19, 2009
My IBM Selectric II either does not type some letters or only partially types them. Sometimes the machine will type a letter and sometimes not. It happens no matter which ball is on the machine. What
First put in a mulyi part form, type on it if the carbon is ok you have have a ribbon problem. The ribbon may be very old or not properly installed or twisted.
DickyO
Sep 30, 2014 | IBM Correcting Selectric II
IBM Selectric II letter printed does not correspond to the letter typed
You could have a broken element (type ball). You could also have a broken or out of adjustment rotate or tilt tape. Those are the two wire bands that control the rotation and tilt of the element.
Dec 11, 2013 | IBM Office Equipment & Supplies
The alignment of a couple of letters (i.e., "m") on by IBM Selectric II is askew. How can this be fixed?
It may be as simple as replacing the element (ball). Remove it and look for broken ao badley worn teeth on the lower edge of the ball.
DickyO
Jul 31, 2013 | IBM Correcting Selectric II
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
My ibm selectric ii type impression is messy and sometimes missing part of the letters. I have check for proper ribbon placement and cleaned the ball element, but the impressions are still dirty looking. ...
Left Rear chrome lever with ABCDE or - marks should be towards the typist and the red ball next to the typing ballo should be moved to a higher number. Messy printing is caused by paper not being held tight against platen(black roller)
Jan 31, 2013 | IBM Correcting Selectric II
MY IBM SELECTRIC II TYPES THE WRONG LETTERS. I CHANGED THE RIBBON, AND THE CORRECT TYPE. WHEN I PUT THE ELEMENT ON, IT STARTING TYPING THE WRONG LETTERS.
Not good. You probably turned the element while removing it and if you are lucky had it come off one of the pulleys, but more likely it came off the wheel under the element. Then you will need a tech.
DickyO
Feb 02, 2010 | IBM Wheelwriter 30 Typewriter
Selectric II type ball not rotating. from what i can see, the cables are all on their pullies. Every number letter and symbol come up wrong. Some letters type on top of each other and come up slightly...
Maybe the rotate tape slipped off either the left or right side pulley. You need to remove the platen and upper case half to fix it. If the tape (thin eighth inch metal tape that when pulled on slightly rotates the ball) is off either pulley, very carefully, without lessening tension on the tape, try to slightly rotate the ball counterclockwise which will loosen the tension on the tape and slip it back on the pulley.
Jan 11, 2010 | IBM Office Equipment & Supplies
Wrong letter types on ibm selectric ii typewriter
Either the element isn't fully installed or you turned it while chnging it and detached the rotate tape if that's the case you need a tech.
DickyO
Sep 17, 2009 | Lexmark Wheelwriter 15 Series II...
Typewritter won't correct!
After you press the corr. key you must retype the wrong letter then type the correct letter.
DickyO
May 15, 2008 | Office Equipment & Supplies
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
248 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
