I recieved a 4th laptop and at first I could vpn with cisco no issues. Then i lost the vpn connection in the middle of the day and could not get connected back up. It was down 1 and 1/2 days I was able to get back in and worked fine for 2 days. now it will not let me back on. I can get to internet and can go to my neighbors and can vpn there. So It looks like I might have some kind of issue with settings for router. FYI This is not a wireless router.
Look at the number of users you have enabled in the router. If you only have 3 and you are using 4 computers, you could be getting the kind of behavior you are describing based on how many computers you have connected at the time.
Comments:
Jun 23, 2009
- Open a browser. Type in 192.168.2.1 in the address field. Press enter and you will get the router's login page. Belkin's default is a blank password. Unless you have changed that (you should) just press Submit. If you have changed it, you need to enter the password that you gave it.
That will give you the Setup screen. At the upper left you will see the LAN tab (vertical tabs here, for those used to horizontal tabs). Click LAN Settings. That will give you a screen labled LAN Settings, the first field down being IP Address where you will see the 192.168.2.1. Go down to the DHCP server section. The On radial should be checked. Below that you'll have IP Pool Starting Address and IP Pool Ending Address. The difference between these is the number of computers that the router is set to handle. It probably starts at 192.168.2.2. If it does, make sure the ending pool address is large enough to accomodate your users - which would include computers that connect occasionally if the IP has not been released. You can check this by clicking the DHCP client list on the left where you started on this screen. That will give you a list of the internal IP addresses assigned from the router's perspective whether or not the computer is currently connected.
Have a belkin router model # f5d7230-4 . Power went off at my house and when it came back on my ps3...
(More)
Have a belkin router model # f5d7230-4 . Power went off at my house and when it came back on my ps3 has been acting up. I get booted offline after about 3 minutes of playtime. I can sign right back on but after about 2 to 3 minutes i get booted right back off. Can u help me out ?
Windows 7 & XP, p printers. XP is cabled, all others wireless. Router sees all devices and...
(More)
Windows 7 & XP, p printers. XP is cabled, all others wireless. Router sees all devices and issues ip adresses. PCs access internet fine, but devices do not see each other on LAN. File/printer sharing appeares to be turned on, but no response from any networked device for either OS.
At my mom's house and they have security enabled wireless connection; when i try to go on internet...
(More)
At my mom's house and they have security enabled wireless connection; when i try to go on internet it automatvalidate certificate.ically connects but says validating identity; then it says unable to
