Question about Avaya AWH-55 Professional Headset
Resync awh55 headset - Avaya AWH-55 Professional Headset
Cable box lights off won't turn on
This happened to me, and here is what I did... For some odd reason all of the lights and cords were plugged in correctly, except I could not hear the game chat. This happens when your headset is UNSYNCED. Take the headset back over to the xbox/ps3 and resync them. If that does not work, unplug every cable/wire to the headset (even from the xbox/ps3) reassemble it and sync it. It should work then. I have no idea why it will suddenly unsync, but fortunately it doesn't happen that often.
May 30, 2014 | Turtle Beach Ear Force X42 Headset
People can hear me on my bluetooth, but I can't hear them. I checked my connections and settings?
Unsync your headset or delete it off the system and resync it. Then check the settings, to make sure they match up
Mar 01, 2012 | Sony Playstation 3 (PS3) Console
Ring alert on headset not working on Avaya AWH55
ask your local admin to change the ringe type in the station configuration
May 24, 2010 | Plantronics Avaya AWH54 (for Partner...
How do i reset this devise to resync with my phone again?
Press and hold the power-on button for 10 seconds or until the LED starts blinking. The headset is now in "Pairing Mode" or "Discoverable" and you can pair with your phone.
Jan 23, 2010 | Plantronics Explorer 230 Bluetooth Headset
My apple ipod froze up, how do i reset it
You need to reset it, just hold down the middle button and the "menu" button for about 7-8 seconds, or until the apple logo appears.
Hope this helps!
Oct 11, 2009 | Apple iPod nano
My ipod has frozen up what can i do
Resync it to iTunes. You may need to reset it to defaults and then resync it, but resync usually works.
Wii Remotes will not resync after using friends Fit Board
there is a flap in the wii open it up. open the spot where the batteries go on the controller. the controller and the wii should have a orange butten press them both at the same time.
Aug 20, 2009 | Nintendo Wii Console
Plantronic 510s
The Voyager 510 is not a good fit for that phone. I would prefer the cs55 or awh55.
The headset will work with the phone, but will not alert you when there is a call.
Jul 03, 2008 | Avaya 5400 Series 5410 Phone
Avaya 4610 ip phone--wireless handset?
CS60 from Plantronics. A bit expensive but perfect
Dec 29, 2007 | Avaya 4610
After charging earpiece my phone will not connect
I WOULD TRY RESYNCING IT ALL TOGETHER. REMOVE IT FROM YOUR PHONE AND PAIR IT UP AGAIN.
Mar 12, 2007 | Jabra BT350 Bluetooth Headset Headset
Radio Communications Logo
Top Avaya Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Avaya Radio Communication Expert? Answer questions, earn points and help others
