Question about Cobra 2500w Power Inverter
Power inverter i have a cobra 2500 watt inverter does it have a fuse that needs to replace
    Problem Solver:
  • 4 Answers
There are 8 40A fuses inside this unit. In the following pics you will see a bank of 4 and another bank with 3 of the 4 removed. I'm currently working on mine as it will cost me more to ship and have Cobra repair than I paid for the unit ($133 to repair). Good luck with your problem
Posted on Aug 24, 2010
    New Friend:
I have a 2500 watt inverted and it won't turn on is there a fuse it's a cobra
Posted on Apr 17, 2016
    Guru:
  • 290 Answers
I believe all inverter have fuses some a visible will some can only bee seen when the inverter is open
Posted on Feb 27, 2010
I need fuses for the 1000 watt - 2000 peak Cobra Power Inverter for my Chevy Silverado 1500
Any auto parts store will have it. Possibly even Walmart depending on if it is specialty. Do you still have the old ones that you're trying to replace?
Sep 30, 2016 | Cobra Electronics - Others
I replaced the 35amp fuses with 40s in my 1550 cobra power inverter will that cause the olp code to pop up
The olp overload refers to Watts and the fuse is monitoring Amps! The rule is replace fuses with the same or lower but in this case it isn't causing the olp!
Oct 22, 2014 | Electronics - Others
Cobra inverter
should probably connect it straight to your battery or you are trying to use something that requires too much power.
Sep 04, 2014 | Cobra 12 Volt 2500 Watt Power Inverter...
I'm trying to run a 750 watt whirlpool compact microwave with a 2500 watt Cobra inverter. The microwave runs normally, but it won't heat. If I plug it in at my house it heats fine. I'm stumped. I load...
I assume your not using a pure sine wave inverter. A lot of electronic devices won't work on a lower cost inverter (modified sine wave) that has a square sine wave, either invest in a true sine wave inverter or don't run sensitive electronic equipment, I'm somewhat surprised you didn't damage the circuit board in the microwave...Below is a link of a inverter that would work if you want to spend the money for one.
2500W 5000 Watt Power Inverter Pure Sine Wave 12V dc 110V 120V ac LCD...
Feb 05, 2018 | Electronics - Others
How do I remove olp message
Its an inverter DC to AC---what since I do not understand the described problem is the unit doing or not doing?
Dec 04, 2012 | Cobra Cpi 2575 5000-watt, 12-volt Dc To...
My cobra 1500 watt inverted doesn't come on wen I
You may not have adequate input voltage. And unless you are hooking up to a forklift battery, the battery will not have adequate current delivery capability for any more than a few seconds at full power of the inverter.
1200 Watts is 100 Amps. 1500 Watts is in the neighborhood of 130 Amps.
Jan 17, 2012 | Cobra Electronics - Others
Whatwire size shoulds I use on my 2500 watt inverter
I would use a minimum of #4 copper. I would get this as a welding cable type because of its flexibility. #2 size is a better choice if you plan on using the inverter for long periods of time.
joe
Jan 26, 2011 | Cobra 2500w Power Inverter
Can a 2500 watt inverter run a 5000 btu air condition?
5000 btu consumes about 500 - 700 W in cooling and obviously it should be running from 2500 W inverter.
It is obviously, but the conditioner has a compressor which needs some more (about 2, 3 times the rated) starting power, which is in it's bigger part reactive power which is not produced by the inverter and depends on the output condensers of the inverter.
It should be tested, and if the start is difficult some more condensers may be added.
Jul 17, 2010 | Cobra 2500w Power Inverter
2500 watt inverter 6 months old is starting to
It sounds like the fan is failing.
Good Luck,
Gilshultz
Dec 03, 2009 | Cobra Electronics - Others
Cobra 2500w Power Inverter Logo
1,395 people viewed this question
Top Cobra Electronics - Others Experts
Gil Shultz
Bill Boyd
hewillseeyou
hewillseeyou
Are you a Cobra Electronics - Other Expert? Answer questions, earn points and help others
