Question about HP LaserJet Pro 400 color M451dn - Printer - color - duplex - laser - Letter/ Legal - 600 dpi x 600 dpi - up to 21 ppm mono / up to 21 ppm color - capacity: 300 sheets - USB/ 10/100Base-TX
Pdf printout is blurry - HP LaserJet Pro 400 color M451dn - Printer - color - duplex - laser - Letter/ Legal - 600 dpi x 600 dpi - up to 21 ppm mono / up to 21 ppm color - capacity: 300 sheets - USB/ 10/100Base-TX
Every 10th line of print is fuzzy. We have tried all the usual fixes, head clean, nozzle check. What next
What should I do if my printout is blurry or smeared? - Epson ...
https://www.epson.com/cgi.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If your printouts areblurry or smeared, try these solutions: ... If you print on both sides of a sheet of paper, smudges may appear on the reverse side of heavily saturated or dark ...Missing: every ‎10th
What should I do if my printout has lines running ... - Epson
https://www.epson.com/cgi-bin/Store/.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If you notice white or dark lines in your prints (also called banding), try these solutions before ...Missing: 10th ‎fuzzy
FAQs for this Product - Epson WorkForce WF-2530, Top ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
EpsonThis link provides access to Top FAQs for the Epson WorkForce WF-2530. ... [ Answer ]; I see the message Printer is Offline when I try to print with a ... [ Answer ]; What should I do if my printout has lines running through it? .... When printing in Windows, how can I prevent an extra page from being ejected after every print job?
Jan 19, 2016 | Epson WorkForce WF-2530
Why are the colors on printouts not overlapping?
You probably need to run an alignment procedure. See the link below.
Align Print Heads On An HP Laserjet 1600
Sep 04, 2014 | HP Color LaserJet 1600
Hi when i print lines appear in my printout - i have ran the maintenance checks and nozzle check utility seems fine although the black looks a bit fuzzy - do you know how to resolve this problem please?...
If you haven't done so, run the alignment setup again. If that doesn't work, put in new cartridges and see if there are still lines in your printout. This will check if it's a printer issue or cartridge issue. Here's a PDF from epson on how to run the alignment setup. See page 11. http://files.support.epson.com/pdf/r300__/r300__pg.pdf
Mar 01, 2011 | Epson Stylus Photo R300 InkJet Printer
Ricoh CL7000 text is blurry/fuzzy
probably only when printing in colour? Black only, is ok right?
It needs to have it's line adjustment procedure done. This is a series of complicated trial and error adjustments performed in service mode that the individual colours are adjusted based on printouts generated by the printer. Can only be adjusted by a service tech with experience with this adjustment.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Not getting printout from pdf folders
Get an updated driver from usa.canon.com
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2279&modelid=6290
In printer properties, device settings, press get device status. The driver should auto-configure with your correct finisher details.
Use the print driver's layout or finishing tab to set two sided print.
Jan 31, 2009 | Canon imageRUNNER 7200 Copier
Canon ir7200
you must have service support tool and new firmware version for that machine
Dec 08, 2008 | Canon imageRUNNER 7200 Copier
Don't take Printout of PDF file from refilled toner
It is possible that from your PDF files, the printing preferences are not configure to print the right cartridge. Before you click the last OK to print from a PDF file, click on Preferences of the printer and see if there is a tab to set the right cartridge (color or black).
Nov 11, 2008 | HP Office Equipment & Supplies
Printer problems
PULL OUT TONER CARTRIDGE SHAKE SIDE TO SIDE AND REINSTALL
Jan 18, 2008 | Brother MFC 9700 All-In-One Laser Printer
HP LaserJet Pro 400 color M451dn - Printer - color - duplex - laser - Letter/ Legal - 600 dpi x 600 dpi - up to 21 ppm mono / up to 21 ppm color - capacity: 300 sheets - USB/ 10/100Base-TX Logo
20 people viewed this question
Seeker5211
Seeker5211
