Question about Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
Replaced coil an plug no spark - Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
2004 chrysler van 3.8 motor replaced coil pack still doesnt fire number 4 cylinder
If the coil pack has a four wire connector, one wire is primary voltage, the other three wires are ground, one ground for each coil, one coil fires two spark plugs. If problem with coil or ground, you would lose spark for two spark plugs. Did you visually check for spark, everywhere? What about the spark plug wire or the spark plug, itself?
Oct 18, 2016 | 2004 Chrysler Town & Country
358.794780 gas blower vac. Won't start, no spark. Replaced coil still no spark
This unit should have a magneto not a coil so better find out what you replaced and check with a dealer or repair centre for your model
Oct 12, 2014 | Garden
Have a 1986 chevy celebrity tec4 an have no fire from coil ive replaced coil checked fuses an have power going to coil still no fire
ignition will trigger if signal from crank sensor, with hei spark plug tester ,read to coil wire and spark plugs wire if spark , depends wich engine
if c3i coil and module the module could be the problems you can check it before replace
hope it helps
Mar 29, 2014 | 1986 Chevrolet Celebrity
I have a broken spark plug wire. Can these be replaced?
Steve:
Yes, the spark plug wire can be replaced, but you have to buy the ignition coil as the spark plug wire is hard wired into the ignition coil.
If the metal spark plug connector has disconnected from the spark plug wire, the connector can be replaced, but if the spark plug wire has been cut you'll need to replace the ignition coil.
Nov 29, 2013 | Homelite 200 mph 400 CFM Gas Blower...
93 sportster only fires on 1 side of coil
Hi Lowbrowbob, on twin cams make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
For a prime suspect please visit the website below:
Good luck
Harley Davidson Sportster error codes and how to access them
Oct 06, 2012 | 1993 Harley Davidson XLH Sportster 883...
Diagnosed with ignition coil problem, replaced coil, spark plugs & wires, inspected pcm, vehicle running rough in gear, acceleration is rough, smooths out when it gets going. oil on one spark plug....
2006 3.9 has to be a T-Bird or LS
There are no spark plug wires
It has Coil-On-Plug individual coils
Plugs don't fail --they get changed at 60,000 miles
give or take,say every 3 years
The front (2) O2 Sensors get repalced at 100,000
miles. The ones closest to the engine
Clean MAF Sensor at least once a year
I have no idea how you inspect a pcm,if your
at home & have no scanner or PC Based Software
Egr Valves fail early on those & other fords
You could test,not look at,actually put an oscilloscope
on the TPS Sensor
Any oil on a spark plug requires a new valve cover gasket
If a coil was replaced based on a code alone,you may have
replaced a good one,not what needed to be replaced if any
Jul 13, 2011 | Ford Freestar Cars & Trucks
I was driving and it just died,we now found we do not have any spark on driver side,can you tell me what it may be,or what we should try to fit it.it will not turn over.Thank you sherry
No spark.This is indication of faulty spark plugs.But spark plugs get power to spark from coil pack. So get the connection between coil pack to spark plugs checked.If it checked out ok then its faulty spark plugs that has to be replaced,but if coil pack has no power then its faulty coil pack that has to be replaced.But if coil pack and spark plugs both checked out ok then this problem is fuel related problem.In this case the fuel pressure needs to be checked.The fuel pressure can be easily checked at any local car garage.If its low then its faulty fuel pump as well as clogged fuel filter,which has to be replaced. The voltage for spark plugs and coil pack in voltmeter will show 12 volts.Its a 12 volt part.If there is no or low volt then there is problem with the part. ------------------ Keep updated with any more queries.Thanks.
Oct 18, 2010 | 1998 GMC Jimmy
No spark at plugs replaced distributer coil an
did you replace the coil wire?
and distrubtorcap and rotor?
Feb 24, 2010 | 1984 Ford F 250
How do i plug in the spark plug coils? what order?
If it's the four cyl., the first coil pack bolts over the #2 spark plug. The #2 coil pack wire plugs into #3 spark plug. The number two coil pack bolts directly over the number four spark plug, and the #2 coil pack wire plugs into the #4 plug. The firing order is 1-4-2-3.
Jun 30, 2009 | 2000 Mazda Protege
Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Logo
Top Poulan Tools & Hardware - Others Experts
L Pfaff
L Pfaff
Bill Boyd
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
