Question about 5000RS-2W Remote Starter with Full-featured Alarm two 2-way 5 button
Button to unlock car problem
The button to unlock my car has a tear in the covering and it is hard to get it to work.Is it possible to get a replacement?
  • 378 Answers
Its hard to get a replacement.
Posted on Jun 18, 2009
My 202 doorbell does not "react" if the button is pushed AFTER my neighbor unlocks his car by using his remote key. Can I change the frequency range of the doorbell?
look for a cover that has small switches under it. You can change frequencies there. You must match the door button the same way .
Nov 19, 2014 | Office Equipment & Supplies
Unlock a 2008 Chevy Silverado
This year model truck WILL allow the truck to be locked if the key fob is left inside, but not while fully engaged in the ignition. If you do not have Onstar service you will have to use a long piece of thin metal, possibly a straightened clothes hanger and work it into the upper part of the driver or passenger side door at the top rear corner. Be careful not to tear the door seal. If it's long enough to reach the power door lock button press it to open the door. If not then fashion a small hook on the end and hook the manual door lock release. There is just enough of a lip to hook on to. Hope this helps.
Oct 12, 2014 | 2008 Chevrolet Silverado 1500 2WD
Car wont start
Push lock, then unlock...Car is in theft mode. If that doesn't work, put the key in the drivers door and "unlock" the door.
Nov 02, 2013 | 20002003 Volvo S40 Keyless Remote with...
1994 Toyota Corolla front passenger side door will not unlock. I can not pull the door locking tab up. I try the central door lock/unlock button and all the doors will lock /unlock except the front
DONT PULL THE lock / unlock button/tab TOO HARD. It will damage further.
Internal linkage/mechanism is not working... Get it repaired by mechanic.
If u want to do it yourself... may be this will help you out. Please refer images10_15_2012_6_14_25_am.jpg10_15_2012_6_14_42_am.jpg
Oct 15, 2012 | Toyota Corolla Cars & Trucks
Remote with new battery seems to have all functions except the lock door function. The armrest control has normal function and will lock and unlock. The remote will then unlock but will not lock. This is a...
possible bad button on key fob.unlock button good lock button bad .get a new clicker you can program it yourself ....put key in ignition turn back and forth 10 times while holding the unlock button on remote.that should work
Aug 05, 2011 | 1998 Ford Explorer
The key fob sometimes does not lock or unlock car doors. i have had a new battery fitted.but still not working properly.
Most of the keyfobs have instrctions on the back, or on the inside cover on how to change the battery in the keyfob and then reactivate.
If you can't find the instructions, you can try the following.
From outside of the vehicle, with all of the doors closed, push the unlock button, then the lock button, then the unlock button, then the lock button.
If that doesn't work;
Those keys/key pads, are highly sensitive to interfearence from other remotes, such as other keys with chips, garage door openers, etc., try to make sure that no other electronic products are near your keyfob.
I hope this helps you.
Feb 19, 2011 | Hyundai Tucson Cars & Trucks
How to unlock?
To Unlock the Sony Ericsson W910I Model mobile from the Network lock You can use the Unlock Code You can get the Unlock Code at
http://www.wickedunlock.com/sony-ericsson-w910i/rs11wp9/ and Unlock the mobile following the Free Unlocking Instructions Below............
Sony Ericsson W910i Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson W910i mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson W910i mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson W910i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson W910i does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2
Oct 20, 2010 | Sony Ericsson Walkman W810i Cellular Phone
Where is the catch??
the button is in the drivers door frame when the door is open there should be a button next to the locking catch. if this does not work the two flaps either side of the hood cover can be lifted up and a hex head allen key can be used to unlock the catches either side of the cover. i've had a problem with the button not working due to electrical problems locking the boot as the cover will not lift with the button if the boot is not locked to prevent damage.
Feb 10, 2009 | 1994 Audi Cabriolet
2001 Oldsmobile Aurora
A common cause for the heated seats to not work is a burned heater element. There is an element under the seat cushion cover, and one under the seatback cover. If either has failed, both will not work.
Nov 05, 2008 | 2001 Oldsmobile Aurora
Mitsubihi projection 52 inch television
boy that is easy to fix for me. the button is mashed in making it always on and the micro-proccor does nothing but looks at that command. you need a new button assemble and it screws in but what button is it If remote works tear it out its just a plastic piece and get your set back to house while waiting on part ,cover the hole with tape. good luck
Aug 15, 2007 | Mitsubishi WD-52525 52" Rear Projection...
5000RS-2W Remote Starter with Full-featured Alarm two 2-way 5 button Logo
125 people viewed this question
Top Scytek Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Scytek Vehicle Part and Accessory Expert? Answer questions, earn points and help others
