Question about HP Tablets & eReaders
Lenco tablet loosing charge - HP Tablets & eReaders
My Nexus 7 Goggle Tablet isn't charging at all. What do I need to do.
Hello. The charging port would need to be replaced. We can fix it needed via mail-in. Visit our website:igsmwireless.com for our contact info. Thanks.
Mar 16, 2017 | Tablets & eReaders
My tablet is not charging
Does the tablet power on when plugged in?
Have you tried a different power outlet, or a different power adapter?
Does the connector on the tablet seem loose or will the tablet charge if you hold the charging cable firmly to the charging socket?
Depending on your answers, it could be a bad charging port on the device, or a bad power adapter/cable, or a problem with electrical outlets. The remaining option would be a battery problem.
I post on behalf of HP.
Jul 01, 2015 | Tablets & eReaders
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Jun 29, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
Tablet won't charge
Check your charging pin. Is it loose? Is it moving or pushed backwards. The charging pins on most of the less expensive tablets are malfunctioning. 4 tablets I've recieved had terrible problem that way. Mostly unfixable, unless that's the problem and you know how the solder such things. Also try a new micro usb and a different electrical outlet, good luck!
Mar 04, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
Charging port loose.no longer charging on my tmax tablet
Try a different Micro-USB cable. It is usually caused by the cable's micro-USB end being loose and not the tablet's charging port. Most smartphones these days use Micro-USB so you can usually try using one of those if you have one.
Aug 04, 2014 | Tablets & eReaders
My charger is loose so I need a USB charger where can I buy one
try amazon if you are looking for just the cord.
Nov 10, 2013 | Tablets & eReaders
Lenco tab-831 Camera has stopped working
try going into the settings/apps and find the camera app.
Try clearing the data
Aug 27, 2013 | Tablets & eReaders
Battery not charging
Is it loose connection. or any problem with charger or tablet. give it to any service centres
May 24, 2013 | Samsung Tablets & eReaders
Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Sep 03, 2009 | Gateway m1300-3004372 Tablet PC
Tablets & eReaders Logo
14 people viewed this question
Top HP Tablets & eReaders Experts
Lawrence Oravetz
ka4iup
ka4iup
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
