Question about Refrigerators
BROKEN SHELF CLIP IN FREEZER
I NEED TO REPLACE A FRONT AND BACK SHELF SUPPORT IN THE FREEZER OF ED25PW SIDE BY SIDE FRIGERATOR/FREEZER. WHERE CAN I FIND THEM?
  • Refrigerators Master
  • 4,655 Answers
Try to find as many numbers or letters after the ED25PW for example model ED25PWXAN01 There are about 30 versions of that refrigerator so start by entering the basic ED25PW into the model and search feature. And go to a link of your choice and click on the photo refrigeration shelves. There you can choose the parts from the display of the parts and components of shelves.
You can visit my link below. Let me know if I can help you further, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Jun 18, 2009
Broken shelf
The small meat or deli drawer tracks show to be avail for replacement as a left and right part. Front and rear screws are shown for each track. Since these parts are shown by themselves, the parts should be replaceable alone. Part# 63001371 is the left track Part# 63001372 is the right. About $5.00 each. The full shelf is a Part# 67001532 @ about $31.00. Pleazer Appliance...
Apr 07, 2014 | Maytag MTB1891AR Top Freezer Refrigerator
My side shelf (which you store milk in) is broken. How do I find out what Whirlpool refrigerator model I have as it's an integrated into a cabinet and so I can't see the number. I need to order a...
Typicaly it is found on a sticker on the back! In your case I suggest taking the broken shelf to a local appliance dealer and they will be able to match it with a replacment for you.
May 07, 2011 | Whirlpool Refrigerators
1999 Chrysler Concorde LXI Rear Speaker replacement
If you mean the rear shelf removal, then you begin by removing the rear seat (lift to release the corner clips on each side holding the cushion to the floor). Then remove the fasteners for the seat belts, then lift the seat back to raise and release it from its clips, and remove it from the vehicle. There are then a lower and upper trim panel around the back shelf that you need to remove (these may be on each side of the shelf, e.g. they are called 'quarter trim' panels). Then you will see some push-pin fasteners that hold the shelf across the front lower edge, so you gently pry out the center push-pin of each one of those to release the fastener. Then you pull the shelf forward to release it from the clips that hold it under the window. Then remove the wire to the center high-mounted brake light. The panel with its speakers attached can then be removed, but also remove the wires from the speakers so you don't break those. connections.
That is the procedure as shown in my '98 manual.
Mar 31, 2010 | 1999 Chrysler Concorde
Freezer works but frigerator does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 14, 2009 | Refrigerators
I need to find replacement parts for my Kenmore side by side refrigerator, Model #596-555510, Mfg #P1190410WW, Ser #9510162258. The door handles are worn, one of the fruit bins is broken, and the support...
You are missing a number in the model number. The model number most likely should be 5969555510 this number runs in the sears system. You need a number 9 in front of the 555510 try this. it seems that this is the only model that will run with what you have provided.
Dec 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Maytag Elevator Shelf
Let me just say, your post helped me, because I realized that I was not going crazy.  But, I was able to find the manual on this frigerator, which was key.  There was one phrase in the manual that gave me help - "when the glass shelf is pushed to the rear, it will align the rear latches.
Manual from whirlpool website: http://shared.whirlpoolcorp.com/assets/pdfs/literature/MSB2154ARA.pdf
So, the rear latches must be installed in such a way that the sliding glass shelf not only touches them, but pushes them into the correct position.
This fact helped me to try different positions, each time testing to see if the glass shelf would do anything.  Finally, I realized that there is a triangular shaped part of the rear latch.  The hypotenuse of the triangle is what comes into contact with the little nub on the underside of the glass shelf.  The nub on the glass shelf pushes the rear latch along the hypotenuse of the right triangle, and into the correct position.
Here is a picture of it installed in my frigerator,which I am sure will tell it better than any words:
Oct 08, 2007 | Maytag MSD2756G Side by Side Refrigerator
Broken Shelf and side shelf
only thing i can tell you is to go to a appliance parts store with the model # and they will find it for you
Aug 01, 2007 | Frigidaire GLRT83TES Top Freezer...
Refrigerators Logo
206 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
