Question about Cell Phones
Bop wont pair with iphone - Cell Phones
How do I pair my bee-bop bb-by bluetooth speaker with my kyocera c6730
Put the device into discovery mode and pair accordingly
Jul 04, 2015 | Kyocera Cell Phones
Why am I unable to even open up the bluetooth menu? The smartwi connection utility will not allow me to access the "bluetooth devices" link.
How are you enabling your bluetooth service on the laptop? Are you pushing a physical blutooth button or starting the service via Windows? Either way if you can turn it on/off and can still connect other devices to it you've isolated the BOP as the culprit. Does the BOP make the beeps after you turn it on and flash its light? If not, you'll need to charge it. If it does, then it is correctly going into auto-pairing mode. If you could provide more information and describe if any of the above events are happening it would help me better understand the issue.
Jan 02, 2015 | Sony VAIO(R) VPCEA44FX/WI 14" Notebook PC...
H681 wont' pair with iphone
Select YES to pair. Enter the passkey 0000 and select OK.
if you have any OTHER devices paired remove them.
1 reset network settings on iphone
2 power off blue tooth device
3 power cycle iPhone
4 attempt to re-pair
Jan 09, 2011 | Motorola Mobility H681 Bluetooth Headset
When i try to turn on the bluetooth function on my 3gs it remains in the search mode- (the circle of death) forever and doesnt pair with my motorola H710! Help!!
it wont pair whatever you do. even if you install a photoshare app on your iphone, it still wont be able to transfer files to and from your iphone. the iphone's bluetooth only works with other iphones/ipod touch.
Aug 03, 2010 | Apple iPhone 3G
My new iphone 3G wont pair with Tom Tom 520 - the tom tom finds the iphone, the iphone seems to find the tom tom, but iphone will not make full connection Any ideas please
i dont think the iphone will pair with the tom tom gps, because they use a different satellite & interface....iphone is running on Google whereas tom tom has its own satellite.
Mar 10, 2010 | Apple iPhone 3G
Have put bluetooth on but it wont paid with any
To your diappointment the Iphone cannot send photos, songs, or anything like that, yet. What you can try is restoring your Iphone and then see if you can pair it with your device. If that doesn't work, then it just means that the device you are trying to pair with it non-compatible with the Iphone.
Oct 27, 2009 | Apple iPhone 3G
When I power up the micromaster 440 i get a screen that shows -----, What does this mean?
may be the BOP is not correctly connected
or the supply provided for 2phase has to be interchanged
Oct 20, 2009 | Inverter Siemens Micromaster 440
I am having the exact same problem!!
Bluetooth on iPhone:
On iPhone:
1) Go to Settings
2) Go to Reset
3) Select "Reset All Setting" (Make sure you save passwords. Data is safe.
On Bluetooth device:
Clear all previous pairings.
Once iPhone reboots, turn on Bluetooth.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 05, 2009 | Apple iPhone 3G
Wont sync with iphone
Make sure that the headset and the phone are both are in "pairing" mode. Even though the iPhone's bluetooth is on you will have to select the headset from the phones bluetooth menu. To get the headset into pairing mode press and hold the "+" sign for 3 seconds. Hope this Helps!
Jun 08, 2009 | Apple iPhone 3G
Pairing headset
you need to have the manual for hour jawbone headset and follow those instructions.  You have to put the headset in "pairing mode" and then once you do that (follow headset instructions) it's simple to just go to settings, bluetooth and tell iphone to search for the headset.
Instead of headset issues, we're having car speaker phone issues.  I have the iphone paired with a motorola bluetooth car speaker, and it works when you are making calls.  However when a call comes in, the speaker doesn't pick up, the phone just rings as normal.  That's a problem as you need to be hands free in our state, and if a cop happens to see you, you're in for it
Nov 21, 2007 | Apple iPhone Smartphone
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
