Question about Kenmore Elite HE5t Washer
Kenmore 5t rl error code
Rl error code on cleaning cycle
  • 5 Answers
SOURCE: code "rL" means???
Code rL or F34 --> Load detected in machine at the beginning of the clean cycle. Push stop, remove clothes from washer & try again. Mine did this to me, even though there was nothing in the washer. I just tried it a second time & all is good again.
Posted on Mar 04, 2009
rylee_smith
  • 8619 Answers
SOURCE: Code F20 is appearing on me washing machine
Hi
Error F 20 means "No Water Detect" error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
You'll need to check for the following--
1- Check the Inlet water valve if it is clogged.
2- Make sure water taps are working fine.
3- Check inlet hoses for kinks or clogs.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 26, 2009
  • 662 Answers
http://www.fixya.com/support/r3608632-f20_error_code
Posted on Jun 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: HE2plus. I keep getting rL on clean washer cycle.
The rl code is displayed when the control detects a load of clothes in the washer during the clean washer cycle.
This code should only come up when you're trying to run a clean cycle.
There can be two causes for this message if there are no clothes in the washer while you're running the clean washer cycle.
The most serious cause of the problem would be the spin bearing. Try and turn the basket by hand and see if you fill any restrictions.
The basket can drab because of the bearing or because there are clothes between the spin basket and outer tub.
Turn the basket by hand and see if you notice anything.
You can also try to remove the belt and run the clean cycle and see if the problem repeats. If the code doesn't repeat with the belt off and there is nothing between the tub and spin basket most likely the spin bearing will have to be replaced. The bearing is part of the rear half of the tub and will require a complete tear down to change.
The rL error code during the clean cycle is likely caused by friction on the spin basket shaft since you indicate that you hear squeaking when the washer is spinning.
The squeaking is normally caused by a bad bearing in the rear tub shell.
I recommend that you have the washer diagnosed and repaired by a Sears service technician.
This type of problem will normally require an extensive tear down of the washer to repair.
It is not a problem that you can normally repair yourself.
Open the door & slowly rotate the spin basket to see if you can feel any kind of drag on the bearings.
If the bearings check good, the control board is sensing a load & will need to be replaced.
If the message rl repeats with the belt off then the most likely cause of this problem is the machine control board.
http://media.fotki.com/1_p,sqfgswqgwssgwfwxgtqsskgwtqkq,vi/ssfqsqssrxkbbdrggfw/1/1303472/5961857/image34400img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have been trying to run the clean cycle on my
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 18, 2010
What does an rL error mean?
The most serious cause of the problem would be the spin bearing. Try and turn the basket by hand and see if you fill any restrictions. The basket can drab because of the bearing or because there are clothes between the spin basket and outer tub. Turn the basket by hand and see if you notice anything.
Mar 10, 2014 | Kenmore HE2 Plus Front Load Washer
I was running the clean cycle on my Kenmore front loading washer and it keeps stopping and reading rL. It wasnt having any probs working on reg cycles, only when I was trying to run the clean cycle. What...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!
Sep 15, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore he plus did not drain and spin, I tried to start a the clean cycle and there is a code "rl". what is wrong?
Sep 08, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore HE2plus washer gives an error code (rL) when we try to do the cleaning cycle.
Oct 19, 2009 | Kenmore HE2 Plus Front Load Washer
My empty washer keeps giving me an rl error while trying to run cleaning cycle
Sep 26, 2009 | Kenmore Elite HE5t Washer
Error code RL keeps occuring when washer is in CLEANER MODE
rl code is load detected in drum during cleaning washer cycle. Book answer is to remove clothes and start the cycle again. Here's everything that Whirpool doesn't want you to know or do to your machine. Don't blame me if you do anything that damages your product. This is a link to the on-line 'technician' only service manual for your washer.
http://www.scribd.com/doc/7075573/Whirlpool-Kenmore-HE2-Plus-Troubleshooting-Tech-Sheet-8540259
May 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mar 03, 2009 | Kenmore HE2 Plus Front Load Washer
Code "rL" means???
Feb 18, 2009 | Kenmore HE2 Plus Front Load Washer
Front load washer problem
rl means there are clothes in washer during cleaning cycle...however .there is a glitch in the program and have seen that rl code with no clothes in washer...don't bother calling repairman it's a program issue with the computer last i heard there was no fix forthcoming and customer were to be told to use normal cycle as they would the clean cycle
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
We get an rl error code when attempting to clean washer. Why and what does it mean?
Is there some thing in the washer ?
rl error
If at the start of the CLEANING WASHER cycle a load is
detected inside the drum.
NOTE: Detects by weight.
Possible Causes/Procedure
Remove clothes from drum and start the cycle again.
Aug 15, 2008 | Washing Machines
Kenmore Elite HE5t Washer Logo
16 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
