Question about KitchenAid KESC307 Electric Kitchen Range
Kebc177kwho occasionally shuts off - KitchenAid KESC307 Electric Kitchen Range
Generac 15000 portable generator: during use the motor revs extremely high and then shut off occasionally.
The reason its shutting down, is probably because its going in to overspeed and the safties are shutting it down to protect the engine. is it doing it under a load or no load.
Aug 13, 2011 | Generac Electrical Supplies
The microwave occasionally shuts itself off. The
You are tripping a high limit switch which means the cooling fan is busted or the microwave is installed to close to something. That or your door interlock switches are sticking.
Dec 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Miller furnace occasionally stops in mid
If the flame looks good prior to the room air blower starting but becomes unstable when the blower starts, you have a crack or hole in the heat exchanger. I strongly suggest your technician do a test on it to see.
Dec 04, 2009 | Heating & Cooling
The TV started turning itself off occasionally a
Most likley what it could be is an interferance in the TV. Modern TV's have a feature that will shut itself off when it is not receving a picture. For instance, after so many minutes of "snow" it will shut off.sometimes this can make the TV think there is no signal at shut itself off.Anyway, I suspect its an interferance issue. Perhaps moving the TV further from the source of the interferance might help.
Sep 17, 2009 | Televison & Video
Cold side of faucet, when turned on, occasionally stops flowing.
Sounds like the valve is comming apart internally. This allows the water to get into places it shouldn't and the water pressure forces the valve closed even though the handle is in the open position. Take it apart and check for loose screws and broken pieces. Lowes or Home Depot should have parts. Don't forget to shut off the valve below the faucet (if the plumber installed one) if not one will have ot shut off incomeing water supply.
Sep 02, 2009 | Price Pfister Plumbing
Computer won't shut off (occasionally)
usually this the indication of Hard driver problem.
this hard drve is on its last lag. it is hardware failure.
get a new Hard Drive and copy everything to the new hard drive. save this one as a backup.
May 22, 2009 | Dell Dimension 4600 PC Desktop
Automatic Shut Off
I ended up returning the item for a replacement per the manufacturer. Wish I had an answer!
Apr 09, 2009 | RCA Televison & Video
Shuts down or locks up occasionally and sometimes it changes menus
if you are using yahoo 9.0 beta then down grade to yahoo 8.1 that will fix the issue.
if you are using and other versions just reinstall yahoo.
that should fix the issue for you
cheers
Sep 23, 2008 | Yahoo Messenger
KitchenAid KESC307 Electric Kitchen Range Logo
22 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
