Question about Ovens
I have a Jade RJRD 3010A convection oven and the electrical bake element needs to be replaced. Where can I get the part I need (given Maytag part # 70003106
Need replacement electrical bake element for the oven. Jade RJRD 3010A part # 70003106
5 Suggested Answers
  • 262 Answers
SOURCE: Bake element in smaller oven replacement
I always unplug oven or turn off power make sure though it will bite ya and hard after turning power off if you do it at the breaker turn stove top on make sure it don come on remember its 220volts and it hurts open oven door remove all racks.Then remove the screws mounting element to oven pull gently towards you (you may have to lift the front up a little) pull old element out until you see the spade connector (plug ins with the wires attached) remove these should be two of them be careful not to let wires go back into the cabinet put new element in hook wires back up to wires push back into the hole and put screws in turn power back on and test. this can also be done by taking the back off also and doing the same thing in the oven.hope this helps ya
good luck
Posted on Dec 08, 2007
kachbibi1
  • 979 Answers
SOURCE: maytag CWE 4800 oven bake element
Go to google and type in model and IOM and it should give you what you need. Replacing the element should not be hard. Just disconnect the power first. My main concern is that you said the oven won't turn off. You may have a control switch problem. Did the element melt at the terminals or in the middle of the element itself?
Posted on Feb 15, 2009
EllaWatson25
  • 725 Answers
SOURCE: Maytag electric range, cre9530. bottom bake element
This is probably your bake element that is out and this is a very simple repair to make.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct element out to you asap as well as part removal/installation instructions.
We hope to get you cooking aain real soon. Ella
Posted on Nov 13, 2009
Macmarkus
  • 2605 Answers
SOURCE: Bake element does not work during convection cooking
Hello and welcome to Fixya.
I hadn't seen your post prior to today, so perhaps you've had a remedy presented to you already.
If you have not, reply to this post and I can recommend a few test to perform that will determine the issue with your oven.
Off the top it sounds like a possible faulty convection heating element or the K3 relay on the board is defective.
I'll watch for your reply.
Thank's,
macmarkus :)
Posted on Jun 18, 2010
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Thank's,
macmarkus :)
Jun 07, 2010 | Thermador SC302T Electric Double Oven
Maytag electric range, cre9530. bottom bake element does not heat...broil element is fine, but when trying to heat oven, bake element does nothing. if you turn on convection, fan will not turn on. any...
Just contact us at:
Nov 12, 2009 | Ovens
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Maytag CWE 4800 oven bake element
Feb 15, 2009 | Maytag CWE4800A Electric Single Oven
Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Dec 10, 2006 | Bosch HBL 455 Stainless Steel Electric...
Ovens Logo
55 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
