Question about InFocus In2112 - Dlp Projector - 3000 Ansi Lumens - Svga 800 X 600 - 4:3 - In2112 Proj Dlp Svga 3000lumen 2100:1 800x600
Infocus IN2112 wrench red light - InFocus In2112 - Dlp Projector - 3000 Ansi Lumens - Svga 800 X 600 - 4:3 - In2112 Proj Dlp Svga 3000lumen 2100:1 800x600
Cannot power on
First check the power cord and the AC out (110/220vac)
If you say "no power", death.
You need to change the power supply.
P5E84-8101 POWER SUPPLY, ALL IN211X
But if you say. "No light", lamp.
You need to check with a good lamp.
them check the firware, must be v2.78.30, if not, you should upgrade it.
Oct 21, 2013 | InFocus IN2112 Projector
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
Projector Works for one minute then the lamp goes out.
sounds like a fan not working or a bad power supply/ballast. If it is a fan that is not working it will cause it to shut down. That would either be a bad fan or bad main board. But, if all fans are working, most likely it's the power supply/ballast.
May 10, 2010 | InFocus IN36 Projector
3 times blinking red light on focus n46 projector
do you mean an infocus? there is no n46. need more info. if it is an infocus, 3 blinks usually means a fan error.
Dec 07, 2009 | InFocus Office Equipment & Supplies
When i turn on the projector it turns off and displays the wrench symbol on the infocus project. need help
there is an issue with either the colorwheel or the power supply. send it in th an infocus service center. try av solutions in ny. they're pretty good.
Nov 04, 2009 | InFocus In2102 Projector
Infocus X3, no light, LED is solid green.
the colorwheel. if it does not spin, the lamp will not light.
Aug 26, 2009 | InFocus Proxima UltraLight X350 Multimedia...
Bulb failures
I experienced the same thing, only to discover it was the ballast that powers the lamp. I believe INFOCUS repairs for $390.00 per the technician that I spoke with on the phone at INFOCUS.
Jun 29, 2008 | InFocus IN72 Multimedia Projector
Infocus LP120 Retrying-Power Light Turns Red...
Usually when the lamp is good and you get this message, the ballast is bad. That is the part thatdrives the lamp. Check with Infocus for a repalacement balast.
Dan
Apr 09, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus in76
reset the Lamp as per shown in the user's manual.
Check the ballast unit, if dont work.
Nov 18, 2007 | InFocus Play Big IN76 Multimedia Projector
InFocus In2112 - Dlp Projector - 3000 Ansi Lumens - Svga 800 X 600 - 4:3 - In2112 Proj Dlp Svga 3000lumen 2100:1 800x600 Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
