Question about CyberLink MediaShow 5
Photos don't match to music length
I have set up a slide show dvd with music..146 photos and six songs...i checked match pictures to match music length...when i preview it it looks perfect,music and pictures match great...when i go to burn it the pictures cycle thru at approx. 17mins,but the music plays for approx 25mins while the pictures start to repeat until the music is done...then returns to the intro...what could be going wrong?
How do you add the music to the slide show?
Dear annettesamto
First do the photos. When you have finished that, click on the "Next" button at the bottom of the window. Now look for your music files by clicking on the "Select Audio Files" button in the "Soundtrack" section. For example, go to "My Documents" and then select the "My Music" folder and click on "Open". Select the music file you want and once again click on "Open". The track you have chosen should now appear in the white area in the "Soundtrack" section. Repeat this to choose more music tracks until you are satisfied with your selection. To delete any tracks from the list, select it in the "Soundtrack" section and then click on the little dustbin to the right and just above the white area where the names of the music tracks are.
Hint: Try to get the combined length of all your music tracks ("Total audio time") close to the "Duration of Slide Show". Then decide how long (in seconds) you want every photo to be displayed before the slide show moves on to the next photo. All your photos will be displayed for the same amount of seconds. In the "Duration" section, at "Set Duration", type in the amount of seconds you would roughly want your photos to be displayed for (for example 8 seconds). If the "Duration of Slide Show" and "Total audio time" is the same or very close, you can ignore the part where it says "Auto-Fit to Soundtrack". However, if the difference is several seconds or more, click on "Auto-Fit to Soundtrack". This will ensure that your slide show (photos) ends when the music ends. It means that your photos may now be displayed for slightly less or more seconds than the amount you indicated, but at least the soundtrack and the photos will end together.
When you are satisfied with your soundtrack, click on "Finish" at the bottom of the window. If the computer asks you if you want to replace an existing file, click on "Yes". The soundtrack window dissapears. Now click on "File" at the top left of the window and choose "Save Project".
You can listen to your soundtrack by clicking on tab 3 ("Produce") and then on the "Enter" button on the remote control.
You should be aware that some music files may not work with SlideShow Expressions, particularly some files that have been downloaded from the internet, for example through iTunes. This has to do with copy-protection and causes some tracks not to play properly. As a rule, though, mp3 files should work fine, as well as tracks ripped from CDs, like wma files. The User Guide gives a list of all the supported music files. The User Guide is on the install disc. To find it, insert your install disc and click on the relevant link that appears, or you can go to "My Computer", right-click on the CD/DVD drive and click on "Explore" to look for it on the install disc; it is a pdf file.
I hope this was helpful. The best of luck to you.
Hendrik Uys
Oct 07, 2012 | Individual SlideShow Expressions
I cannon figure out how to add music from my computer to the slide show....please help me....I have 5 songs on my desktop and I cannot seem to figure out how to get them to slideshow...
Best jbannon257
There could be a number of reasons why you're having trouble adding music files to your slide shows. First I'll lay out the procedure and afterwards I'll give some hints / a link to individualsoftware.com where problems with audio files are discussed.
The procedure (adding music files using SlideShow Expressions):
The programme opens and you are automatically in tab 1: "Add Media".
Click on "Create New Slide Show". Click on "Add Photos"; tell the programme where the photos are, select them, insert them, change their positions if necessary.
Now:
1. Click on "Next" at the bottom of the screen.
2. At "Soundtrack", click "Select Audio Files", then tell the programme where the music files are located on your computer, click to highlight a specific music file, click on "Open". The music file you selected now appears in the Soundtrack window. Repeat this until all the music files you want appear in the Soundtrack window. (You can delete any of them by clicking to highlight any specific file and then click on the little rubbish can icon.) As you go along, the total audio time for the slide show / chapter is displayed as well as the "Duration of Slide Show".
3. In the "Duration" section, you have the option to set the length of time you want per slide (seconds) - usually 8 to 10 seconds is best. (All your slides will follow this instruction; you can't set the duration of individual slides to a different time.) At "Auto-Fit to Soundtrack", you alter the duration of the slides to fit the length of the soundtrack. (This cancels out the previous seconds-per slide setting.) You must therefore choose music tracks that, when added together, will approximately span the whole length of the slide show and then you can fine-tune this by clicking the "Auto-Fit to Soundtrack" option.
4. When you are satisfied with your choice of music tracks and the length of your slide show, click on "Finish".
Issues with music files when using SlideShow Expressions
A.
According to the User Guide (section 3-3) - included on the install disc as a pdf file - the supported audio formats are: mp3, wma, wav, ra. Make sure that your computer also meets all of the requirements (on the box).
B.
Photo & Video Expressions is not compatible with audio files that have been protected by Digital Rights Management (DRM) functionality. Most audio files purchased online through Internet music retailers like iTunes, Urge, or Rhapsody are encrypted with some form of DRM. Similarly, audio files that have been extracted from a CD or DVD (the process known as "ripping") using certain media applications (iTunes, Windows Media Player, etc.) often have default settings that encrypt the files extracted.
There is no way to used DRM audio files purchased from online music retailers with Photo & Video Expressions. However, if you want to used music and audio files that you have extracted from your CD collection, then all you have to do is change the ripping setting in your media application before you extract the files to your computer.
Go to the following site to read about how to change your ripping settings:
http://www.individualsoftware.com/support/frequently_asked_questions.html
Type your question OR (below):
"Photo & Video Creativity": choose "SlideShow Expressions" from drop-down menu, click "Go".
A window appears with options on problems, e.g. "Why aren't my audio files showing?"; "Why won't my music files work?" Click to read.
The best of luck to you. From: 11407336.
PS. Try individualsoftware.com
May 30, 2011 | Individual SlideShow Expressions
How do I remove a tumbnail from a photo?
Once you've added you're photos, you can set a different photo to act as thumbnail (the programme automatically chooses the first photo/slide, indicated by a little green ticked box sign).
To change the thumbnail to a different photo, highlight the photo you want as thumbnail by clicking it - the frame will change to yellow - and then click on the green ticked box command ("Set Thumbnail") at the top of the window.
You cannot alltogether delete the thumbnail, because every slide show you create needs to have a thumbnail to link the slide show to the menu screen at the start of your DVD. So, on your menu screen there will always be at least one thumbnail. (The black thumbnail that appears in the middle of your screen when you first open the programme, is a "place holder". It needs to be there and it cannot be deleted. Once you've created a slide show, it will be replaced with the photo you have chosen to be the thumbnail. Every time you create a new slide show, a new thumbnail will be added to your menu screen. The position of thumbnails can be changed, using the second ("Edit") Tab.
You will find a User's Guide on the install disc. It can be accessed by inserting the install disc and clicking on the relevant link, or you can right click on your CD/DVD drive (in "My Computer") and then click on "Explore" to look for it on the install disc - it's a pdf file.
Jan 27, 2011 | Individual SlideShow Expressions
When I make a DVD slide show using around 140 pictures...with music, and I play it on T.V. it hangs up and stops at about the 54th picture?
Maybe your problem is related to the size of your photos. Or maybe photo no. 54 has a problem, too large maybe. I've had a problem with SlideShow Expressions where I wasn't able to burn a project to disc. It was a very large project: 466 photos. Quite a lot of the photos were larger than 2 MB, some 3.5 MB. The problem was solved by resizing all the photos that were very large. I resized to about 500 KB, but maybe you do not need to go as small. Using Microsoft Office Picture Manager, I really can not tell the difference between my original photos and the photos in my slideshow project - resizing doesn't necessarily affect the quality of the end product. I also chose not to archive the photos on the disc, because when the project is really really large, this also can cause the writer drive not to function properly. However, 140 photos doesn't sound that many to me. Length doesn't seem to be your problem. But maybe you could experiment with photo sizes. Yes, I know, it's a lot a work, but the end product could be worth it.
11407336
Sep 02, 2010 | Individual SlideShow Expressions
How do i get music to play at the same time as showing my photos?
put songs on mp3 player so it can have songs then it can show a picture with the songs that u r listen to rite now but here the thing if u have the music playing with ur music it can shut down the music then it come up the picture
May 21, 2010 | Audio Players & Recorders
How to delete songs and pictures that are already on it?
Delete songs
-Under Devices 2 d left hand side u c ur ipod name.. 2 its left u c a small arrow.. wen u click on dat u get a dropdown list sayin MUSIC VIDEOS etc..
-Click on MUSIC option u'l c a list of music..
-Right click on d song which ya don need n delete..:)
Delete pictures
-2 d left hand side, Click on the ipod name under devices
-Look 4 d TAB which says photos.. click on it..
-There is a tick box in front of d phrase SYNC PHOTOS FROM.. untick this..
-A lil box will come up saying want to delete photos or dont delete photos.. click on delete photos
-After dat 2 d bottom right derz APPLY button.. Click on this..
-Later click on SYNC button.. al d photos'l b deleted..
May 02, 2010 | Sharper Image Audio Players & Recorders
The pictures on my sansa mp3 8gb
I didn't realize the sansa clip supported pictures - are sure you posted in the right section?
Just giving you a hard time. If you have a Sansa Fuze 8GB:
Looping a Slideshow
1. Press Submenu button while viewing photos.
2. Scroll to Loop and select it.
3. Use the thumbwheel to select Loop on or off.
4. Press the Select button.
5. Press the |<< button to return to previous menu.
Specifying the Slide Duration
1. Press Submenu button while view photos.
2. Scroll to Slide Time and select it.
3. Use the thumbwheel to highlight and select the desired duration (from 2
seconds to 30 seconds).
4. Press the Center button.
5. Press the |<< button to return to the previous menu.
Selecting Slideshow Music
2. Use the thumbwheel to highlight Slideshow Music and select it.
3. Select Current Song (if a song is currently playing) or Music Go List
(plays music from the Go List) then press the Center button.
4. Press the |<< button to return to previous menu.
-Tha Mp3 Doctor
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Slide show dvd
Speaker's notes can turn a rambling presentation into one that's sharp and interesting. Check out this simple outline for teaching your PowerPoint students how to set up notes to improve their presentation delivery.Many PowerPoint classes focus exclusively on the fundamentals of creating and formatting slides, adding special effects, and running...
Jan 21, 2008 | Computers & Internet
Slide Show music
Hi, What program are you using to create this slide show please?
Nov 27, 2007 | HP Photosmart C6180 All-In-One InkJet...
CyberLink MediaShow 5 Logo
26 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
