Question about Kyocera Mita Office Equipment & Supplies
Fuser connector error code c6020
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 245 Answers
Press10871087 after press 163 reast
Posted on Dec 24, 2014
5 Suggested Answers
  • 143 Answers
SOURCE: Error code C6020
Sounds like you have a faulty thermistor. (heat sensing device) The 6020 indicates an abnormally HIGH temperature. If the readings are greatly different in the two thermistiors or one is not touching the hot roller could also be the problem.
Posted on Aug 01, 2009
SOURCE: Ricoh Afico 2075 sc551 error code. the thermistors
Press total clear (yellow key) , 107 and press and hold the clear stop key (orange key) more than 3 seconds, shut off and on the copy.
Good luck.
Posted on Sep 14, 2009
SOURCE: How to fix Error code C6020
I have The Km C2520 with the same C6020 code. Is the solution the same?
Posted on Apr 24, 2010
  • 1833 Answers
SOURCE: hi I have changed 2 fuser
This is the error of high temperature in fixing unit. It may occur for a firmware update. Have you update firmware of the copier recently?
First update the firmware in previous, it may solve your problem. Check the electric outlet if there is any problem with voltage flow and check also the power cord of the printer. If there is no problem then check the fuser plug connector. Check the Thermistor, it may not work properly. You may have to replace the fixing unit finally.
Posted on Jun 30, 2011
Kyocera DC 2018 error code c6020
This is a fuser or heater code. need to test the thermofuse that is in the fuser. If you can see the fuser when you turn on there should be a lite on, if not no heat and machine will show that code. Possible need fuser t or thermo fuse replacement . Good Luck Remember if fuser is on it is very Hot do not touch with fingers...
Mar 29, 2017 | Kyocera Office Equipment & Supplies
Error code c6020
you need to reset the fixing unit. go to mode and input 163 then start off then on.
Feb 28, 2014 | Kyocera Mita Office Equipment & Supplies
Code c6020 180
That is a fuser error. Replace the fuser & reset the code in service mode. You will also want to update the firmware of the machine.
Dec 13, 2013 | Kyocera KM-1505 Copier
180c6020 error
fuser error,problem in fuser
Dec 13, 2013 | Kyocera Taskalpha 180 Maintenance Kit...
Error c6020
this is a fuser error. go into service mode( in the copier standby press 10871087 on the keypad) and go to u163 fuser error reset. If this does not work you might have to consult a service centre.
How to solve error c6020 for Kyocera KM-2035 copier? it has stopped
The C6020 is a fuser error code and should be checked out by a Kyocera tech.
May 18, 2010 | Kyocera KM-1505 Copier
Error c6020
Raggy2010 posted on this toppic Order the modified fuser plug connector. There is also a later firmware update to fix this code. This code happened to me on a few selected machines after I did firmware upgrades to add the interrupt button on the touch screen and to speed up the loading time. The thermistor is not guilty!
Feb 23, 2010 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
Jan 26, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
50 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
